Piriform Forum
Return to Piriform  CCleaner  Defraggler  Recuva  Speccy
Welcome Guest ( Log In | Register )
Closed TopicStart new topic
> Add A Program To Winapp2.ini, Add additional programs to CCleaner.
TwistedMetal
post May 11 2005, 08:46 AM
Post #1
Forum Moderator
Group Icon
Group: Moderators
To learn about winapp2.ini or how to make program entries for CCleaner. Please read the Piriform Docs (Advanced Usage>CCleaner .INI files>How to add your own program for CCleaner to clean). Simply copy and paste the new entry in to winapp2.ini. Note: You will have problems cutting and pasting with Internet Explorer.
To post a new entry, just send me a Personal Message. I will add the new entry ASAP. To report additions for current programs in winapp.ini send MrG a Personal Message.
DISCLAIMER
These entries are not supported by Piriform. These entries have not been tested by the maker of CCleaner. Use these at your own risk, these entries were created and tested by users of the CCleaner Forum. Piriform can not be held responsible for any action that these entries do. If you find a bad entry, please report it to me by Personal Message and I will look into the matter.
A download link for winapp2.ini is located at the bottom of this post.
To receive email notification when winapp2.ini is updated, just click on Track this topic, and select what option you want. You must be a CCleaner Forum Member to do this!
NOTE: Due to loading time and length. The winapp2.ini contents will be in a code box.
Updated 2/22/09
Added Ashampoo Burning Studio 09
Added Auslogics Free Utilities
Added AutoIt3
Added Avi-Mux GUI
Added LogMeIn
Added MS Visual Studio.NET 03
Added PDFCreator
Added TeraCopy
Updated Mp3tag
Listed in Alphabetical Order
CODE
[*32bit Web Browser]
LangSecRef=3022
DetectFile=%ProgramFiles%\32BITWEB\32BW.exe
Default=True
FileKey1=%ProgramFiles%\32BITWEB\Data|LastURL.dat
FileKey2=%ProgramFiles%\32BITWEB\Data|LastURL.DA0
[*3GP Video Converter]
LangSecRef=3023
Detect=HKCU\Software\ImTOO\3GP Video Converter
Default=True
RegKey1=HKCU\Software\ImTOO\3GP Video Converter\Settings|last_openpath
RegKey2=HKCU\Software\ImTOO\3GP Video Converter\Settings|OuputDir
[*A-squared Free]
LangSecRef=3024
Detect=HKLM\Software\Emsi Software GmbH\a-squared Free
Default=True
FileKey1=%userprofile%\My Documents\a-squared\Reports|*.*
FileKey2=%programfiles%\a-squared Free\Logs|*.*
[*Ace Utilities]
LangSecRef=3024
Detect=HKCU\Software\Acelogix\Ace Utilities
Default=False
FileKey1=%userprofile%\My Documents\Ace Utilities Backups|*.reg
[*Acronis True Image]
LangSecRef=3024
Detect=HKCU\Software\Acronis\TrueImage
Default=True
FileKey1=%userprofile%\Application Data\Acronis\TrueImage\Logs|*.log
[*Acronis True Image Home]
LangSecRef=3024
Detect=HKCU\Software\Acronis\TrueImageHome
Default=True
FileKey1=%allusersprofile%\Application Data\Acronis\TrueImage\Logs|*.log
[*Adaptec's Audio CD]
LangSecRef=3024
Detect=HKCU\Software\Adaptec
Default=True
RegKey1=HKCU\Software\Adaptec\AUDIO_CD_INFO
[*Adobe Acrobat 5.0]
LangSecRef=3021
Detect=HKCU\Software\Adobe\Adobe Acrobat\5.0\AVGeneral
Default=True
RegKey1=HKCU\Software\Adobe\Adobe Acrobat\5.0\AVGeneral\cRecentFiles
[*Adobe Acrobat 6.0]
LangSecRef=3021
Detect=HKCU\Software\Adobe\Adobe Acrobat\6.0\AVGeneral
Default=True
RegKey1=HKCU\Software\Adobe\Adobe Acrobat\6.0\AVGeneral\cRecentFiles
[*Adobe Acrobat 7.0]
LangSecRef=3021
Detect=HKCU\Software\Adobe\Adobe Acrobat\7.0\AVGeneral
Default=True
RegKey1=HKCU\Software\Adobe\Adobe Acrobat\7.0\AVGeneral\cRecentFiles
[*Adobe Acrobat Reader 4.0]
LangSecRef=3021
Detect=HKCU\Software\Adobe\Acrobat Reader\4.0
Default=True
RegKey1=HKCU\Software\Adobe\Acrobat Reader\4.0\AdobeViewer\avpRecentFile1
RegKey2=HKCU\Software\Adobe\Acrobat Reader\4.0\AdobeViewer\avpRecentFile2
RegKey3=HKCU\Software\Adobe\Acrobat Reader\4.0\AdobeViewer\avpRecentFile3
RegKey4=HKCU\Software\Adobe\Acrobat Reader\4.0\AdobeViewer\avpRecentFile4
[*Adobe ImageReady CS]
LangSecRef=3021
Detect=HKCU\Software\Adobe\ImageReady 8.0
Default=True
RegKey1=HKCU\Software\Adobe\ImageReady 8.0\Preferences\URLHistory
RegKey2=HKCU\Software\Adobe\ImageReady 8.0\Preferences|SaveDir
RegKey3=HKCU\Software\Adobe\ImageReady 8.0\Preferences\RecentFiles
[*Adobe Photoshop 5.5]
LangSecRef=3021
Detect=HKCU\Software\Adobe\Photoshop\5.5
Default=True
RegKey1=HKCU\Software\Adobe\Photoshop\5.5\VisitedDirs
[*Adobe Photoshop CS3]
LangSecRef=3021
Detect=HKCU\Software\Adobe\Photoshop\10.0
Default=True
RegKey1=HKCU\Software\Adobe\Photoshop\10.0\VisitedDirs
RegKey2=HKCU\Software\Adobe\MediaBrowser\MRU\Photoshop\FileList
[*Advanced Searchbar]
LangSecRef=3022
Detect= HKCU\Software\Advanced Searchbar\Toolbar
Default=True
RegKey1=HKCU\Software\Advanced Searchbar\Toolbar\Historysearchbox1
[*Ahead Nero Burning Rom 8]
LangSecRef=3021
Detect=HKCU\Software\Nero\Nero8
Default=True
RegKey1=HKCU\Software\Nero\Nero8\Cover Designer\Recent File List
RegKey2=HKCU\Software\Nero\Nero8\Nero - Burning Rom\Recent File List
FileKey1=%userprofile%\Application Data\Nero\Nero8\Nero Burning ROM|*.log
[*Ahead Nero PhotoSnap]
LangSecRef=3021
Detect=HKCU\Software\ahead\Nero PhotoSnap
Default=True
RegKey1=HKCU\Software\ahead\Nero PhotoSnap\Recent File List
[*Ahead NeroSearch]
LangSecRef=3021
Detect=HKCU\Software\Ahead\NeroSearch
Default=True
RegKey1=HKCU\Software\Ahead\NeroSearch\NeroSavedSearches\SavedSearches
[*Ahead NeroVision 2.0]
LangSecRef=3021
Detect=HKCU\Software\ahead\NeroVision\2.0
Default=True
RegKey1=HKCU\Software\ahead\NeroVision\2.0\RecentFiles
[*AI Roboform Search]
LangSecRef=3022
Detect=HKCU\Software\Siber Systems
Default=True
RegKey1=HKCU\Software\Siber Systems\RoboForm\Query-MRU
[*AkelPad]
LangSecRef=3024
Detect=HKCU\Software\Akelsoft\AkelPad
Default=True
RegKey1=HKCU\Software\Akelsoft\AkelPad\Recent
RegKey2=HKCU\Software\Akelsoft\AkelPad\Search
[*Alcohol 52%]
LangSecRef=3023
Detect=HKCU\Software\Alcohol Soft
Default=True
RegKey1=HKCU\Software\Alcohol Soft\Alcohol 52%\Images
RegKey2=HKCU\Software\Alcohol Soft\Alcohol 52%\MountedMRU\0
RegKey3=HKCU\Software\Alcohol Soft\Alcohol 52%\Basic|Image File Path
RegKey4=HKCU\Software\Alcohol Soft\Alcohol 52%\Options\Image Making Wizard|ImageFilePath
RegKey5=HKCU\Software\Alcohol Soft\Alcohol 52%\Options\Image Making Wizard|ImageName
[*Always Right]
LangSecRef=3024
Detect=HKCU\Software\AlwaysRight
Default=True
FileKey1=%ProgramFiles%\Superhunter\Always Right\FileBackup|*.*
FileKey2=%ProgramFiles%\Superhunter\Always Right\RegBackup|*.*
[*Amsn - Display Pictures]
LangSecRef=3021
Default=False
Detect=HKCU\Software\aMSN
FileKey1=%userprofile%\amsn\displaypic\cache|*.*
[*Anim8or]
LangSecRef=3021
Detect=HKCU\Software\Silicon Valley Software\Anim8or
Default=True
RegKey1=HKCU\Software\Silicon Valley Software\Anim8or|File1
RegKey2=HKCU\Software\Silicon Valley Software\Anim8or|File2
RegKey3=HKCU\Software\Silicon Valley Software\Anim8or|File3
RegKey4=HKCU\Software\Silicon Valley Software\Anim8or|File4
[*AntiVir Personal 8]
; Removes only the safe to remove files .tmp and .log!
LangSecRef=3024
Detect=HKLM\SOFTWARE\Avira\AntiVir PersonalEdition Classic
Default=True
FileKey1=%commonappdata%\Avira\AntiVir PersonalEdition Classic\BACKUP\FAILSAFE|*.tmp
FileKey2=%commonappdata%\Avira\AntiVir PersonalEdition Classic\LOGFILES|*.log
FileKey3=%ProgramFiles%\Avira\AntiVir PersonalEdition Classic|*.tmp
FileKey4=%ProgramFiles%\Avira\AntiVir PersonalEdition Classic\FAILSAFE|*.tmp
[*AOL Instant Messenger]
LangSecRef=3022
Detect=HKCU\Software\America Online\AOL Instant Messenger ™\CurrentVersion
Default=True
RegKey1=HKCU\Software\America Online\AOL Instant Messenger ™\CurrentVersion\recent IM ScreenNames
RegKey2=HKCU\Software\America Online\AOL Instant Messenger ™\CurrentVersion\recent ScreenNames
RegKey3=HKCU\Software\America Online\AOL Instant Messenger ™\CurrentVersion\Users
[*Arasan Chess]
LangSecRef=3024
Detect=HKCU\Software\Arasan\Arasan
Default=True
RegKey1=HKCU\Software\Arasan\Arasan\Recent File List
[*Ashampoo Burning Studio 5]
LangSecRef=3021
Detect=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5
Default=True
RegKey1=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5\Burn Image Project\SelectImage
RegKey2=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5\Data Disc Project\AddDialog
RegKey3=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5\Data Disc Project\DumpImage
RegKey4=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5\Unknown Project\AddDialog
[*Ashampoo Burning Studio 6]
LangSecRef=3021
Detect=HKCU\Software\Ashampoo\Ashampoo Burning Studio 6
Default=True
RegKey1=HKCU\Software\Ashampoo\Ashampoo Burning Studio 6\Burn Image Project\SelectImage
RegKey2=HKCU\Software\Ashampoo\Ashampoo Burning Studio 6\Data Disc Project\AddDialog
RegKey3=HKCU\Software\Ashampoo\Ashampoo Burning Studio 6\Unknown Project\AddDialog
[*Ashampoo Burning Studio 6 Free (Logs)]
LangSecRef=3023
Default=True
FileKey1=%userprofile%\Application Data\Ashampoo\Ashampoo Burning Studio 6 Free\Logs|*.*
[*Ashampoo Burning Studio 7]
LangSecRef=3021
Detect=HKCU\Software\Ashampoo\Ashampoo Burning Studio 7
Default=True
RegKey1=HKCU\Software\Ashampoo\Ashampoo Burning Studio 7\Burn Image Project\SelectImage
RegKey2=HKCU\Software\Ashampoo\Ashampoo Burning Studio 7\Data Disc Project\AddDialog
RegKey3=HKCU\Software\Ashampoo\Ashampoo Burning Studio 7\Unknown Project\AddDialog
[*Ashampoo Burning Studio 8]
LangSecRef=3021
Detect=HKCU\Software\Ashampoo\Ashampoo Burning Studio 8
Default=True
RegKey1=HKCU\Software\Ashampoo\Ashampoo Burning Studio 8\Data Disc Project\AddDialog
[*Ashampoo Burning Studio 07]
LangSecRef=3021
Detect=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007
Default=True
RegKey1=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007\Burn Image Project\AddDialog
RegKey2=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007\Data Disc Project\AddDialog
RegKey3=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007\Dump Image Project\DumpImage
RegKey4=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007\Unknown Project\AddDialog
FileKey1=%appdata%\Ashampoo\Ashampoo Burning Studio 2007\Logs|*.*
[*Ashampoo Burning Studio 09]
LangSecRef=3024
Detect=HKLM\Software\Ashampoo\Ashampoo Burning Studio 2009
Default=True
FileKey1=%appdata%\Ashampoo\Ashampoo Burning Studio 2009|backupmetainfo.xml
FileKey2=%appdata%\Ashampoo\Ashampoo Burning Studio 2009\Logs|*.xml
FileKey3=%appdata%\Ashampoo\Logs|*.txt
[*Audacity]
LangSecRef=3023
Detect=HKCU\Software\Audacity
Default=True
RegKey1=HKCU\Software\Audacity\Audacity\RecentFiles
[*AusLogics Disk Defrag]
LangSecRef=3024
Detect=HKCU\Software\AusLogics\Disk Defrag\1.x
Default=True
FileKey1=%ProgramFiles%\AusLogics Disk Defrag\reports|*.*
[*Auslogics Free Utilities]
; Cleans all three free Auslogic utilities reports and logs:
; Disk Defrag, Registry Defrag, and System Information
LangSecRef=3024
Detect=HKCU\Software\Auslogics
Default=True
FileKey1=%appdata%\Auslogics\Disk Defrag\Reports|*.*
FileKey2=%appdata%\Auslogics\Registry Defrag\Logs|*.*
FileKey3=%appdata%\Auslogics\Registry Defrag\Reports|*.*
FileKey4=%appdata%\Auslogics\System Information\Reports|*.*
[*AusLogics Registry Defrag]
LangSecRef=3024
Detect=HKCU\Software\AusLogics\Registry Defrag\4.x
Default=True
FileKey1=%ProgramFiles%\AusLogics Registry Defrag\Data\RegistryDefrag|*.*
FileKey2=%ProgramFiles%\AusLogics Registry Defrag\Reports\Registry Defrag|*.*
[*AutoIt3]
;AutoIt3 and SciTE4 Editor
LangSecRef=3021
Detect=HKCU\Software\AutoIt v3
Default=True
RegKey1=HKCU\Software\AutoIt v3\Aut2Exe|LastExeDir
RegKey2=HKCU\Software\AutoIt v3\Aut2Exe|LastIcon
RegKey3=HKCU\Software\AutoIt v3\Aut2Exe|LastIconDir
RegKey4=HKCU\Software\AutoIt v3\Aut2Exe|LastScriptDir
FileKey1=%userprofile%|SciTE.*
[*Avant Browser]
LangSecRef=3022
DetectFile=%ProgramFiles%\Avant Browser\avant.exe
Default=True
FileKey1=%appdata%\Avant Browser|keywords.dat
FileKey2=%appdata%\Avant Browser|pages.dat
FileKey3=%appdata%\Avant Browser|recents.dat
FileKey4=%appdata%\Avant Browser|reopen.dat
[*Avast Antivirus]
LangSecRef=3024
Detect=HKCU\Software\ALWIL Software\Avast
Default=True
FileKey1=%ProgramFiles%\Alwil Software\Avast4\DATA\report|avast.xsl
FileKey2=%ProgramFiles%\Alwil Software\Avast4\DATA\report|Resident protection.txt
FileKey3=%ProgramFiles%\Alwil Software\Avast4\DATA\report|Simple user interface.txt
FileKey4=%ProgramFiles%\Alwil Software\Avast4\DATA\report|Simple user interface*.xml
FileKey5=%ProgramFiles%\Alwil Software\Avast4\DATA\log|*.*
[*AVG AntiVirus 8.0]
LangSecRef=3024
Detect=HKLM\SOFTWARE\AVG\Avg8
Default=True
FileKey1=%allusersprofile%\Application Data\avg8\Log|*.log
FileKey2=%allusersprofile%\Application Data\avg8\scanlogs|*.log
FileKey3=%allusersprofile%\Application Data\avg8\Log|*.xml
FileKey4=%allusersprofile%\Application Data\avg8\update\backup|*.*
[*Avi-Mux GUI]
; Deletes logs and any possible crash .dmp files.
LangSecRef=3023
DetectFile=%ProgramFiles%\AVIMuxGUI\AVIMux_GUI.exe
Default=True
FileKey1=%ProgramFiles%\AVIMuxGUI|AVI-Mux GUI - Logfile*
FileKey2=%ProgramFiles%\AVIMuxGUI|*.dmp
[*Avira RootKit Detection]
LangSecRef=3024
DetectFile=%ProgramFiles%\Avira GmbH\Avira RootKit Detection\avirarkd.exe
Default=True
FileKey1=%ProgramFiles%\Avira GmbH\Avira RootKit Detection|avirarkd.log
[*AVS Disc Creator (Logs)]
LangSecRef=3021
Detect=HKLM\Software\AVS\DiscCreator
Default=True
FileKey1=%windir%|coredw.log
FileKey2=%windir%|datawriter.log
[*Azureus]
LangSecRef=3022
DetectFile=%userprofile%\Application Data\Azureus\.lock
Default=True
FileKey1=%userprofile%\Application Data\Azureus\tmp|*.*
FileKey2=%userprofile%\Application Data\Azureus|*.bak
FileKey3=%userprofile%\Application Data\Azureus|*.log
FileKey4=%userprofile%\Application Data\Azureus\active|*.bak
FileKey5=%userprofile%\Application Data\Azureus\plugins\advancedstatistics|*.txt
FileKey6=%userprofile%\Application Data\Azureus\plugins\progressbar|*.txt
[*Babylon]
LangSecRef=3024
Detect=HKCU\Software\Babylon\Babylon Translator\UserInfo
Default=True
RegKey1=HKCU\Software\Babylon\Babylon Translator\UserInfo\History
[*Boinc]
LangSecRef=3024
DetectFile=%ProgramFiles%\BOINC\boinc.exe
Default=True
FileKey1=%ProgramFiles%\BOINC|stdout*.*
FileKey2=%ProgramFiles%\BOINC|stderr*.*
[*BitDefender 9]
LangSecRef=3024
Detect=HKLM\Software\Softwin\BitDefender Antivirus
Default=True
FileKey1=%ProgramFiles%\Softwin\BitDefender9\Logs|*.*
[*BitTorrent]
LangSecRef=3022
DetectFile=%ProgramFiles%\BitTorrent\bittorrent.exe
Default=True
FileKey1=%userprofile%\Application Data\BitTorrent\incomplete|*.*
[*Borland C++ Builder 5.0]
LangSecRef=3024
Detect=HKCU\Software\Borland\C++Builder\5.0
Default=True
RegKey1=HKCU\Software\Borland\C++Builder\5.0\Closed Files
RegKey2=HKCU\Software\Borland\C++Builder\5.0\Closed Projects
RegKey3=HKCU\Software\Borland\C++Builder\5.0\Session
[*Borland Developer Studio 2006]
LangSecRef=3024
Detect=HKCU\Software\Borland\BDS\4.0
Default=True
RegKey1=HKCU\Software\Borland\BDS\4.0\Closed Files
RegKey2=HKCU\Software\Borland\BDS\4.0\Closed Projects
KegKey3=HKCU\Software\Borland\BDS\4.0\Session
[*CDex]
LangSecRef=3024
Detect=HKLM\SOFTWARE\CDex
Default=True
FileKey1=%userprofile%\My Documents\My Music\CDDB|*.txt
[*Centarsia]
LangSecRef=3021
Detect=HKCU\Software\Centarsia
Default=True
RegKey1=HKCU\Software\Centarsia|RecentImage0
RegKey2=HKCU\Software\Centarsia|RecentImage1
RegKey3=HKCU\Software\Centarsia|RecentImage2
RegKey4=HKCU\Software\Centarsia|RecentImage3
RegKey5=HKCU\Software\Centarsia|RecentImage4
RegKey6=HKCU\Software\Centarsia|RecentImage5
RegKey7=HKCU\Software\Centarsia|RecentImage6
[*CloneCD]
LangSecRef=3021
Detect=HKLM\Software\SlySoft\CloneCD
Default=True
RegKey1=HKCU\Software\SlySoft\CloneCD\Settings|ImageFileName
[*CoffeeCup GIF Animator]
LangSecRef=3024
Detect=HKCU\Software\CoffeeCup Software\GIF Animator
Default=True
RegKey1=HKCU\Software\CoffeeCup Software\GIF Animator\Settings\MRU
[*Compare It!]
LangSecRef=3021
Detect=HKCU\Software\grigsoft.com\Compare It!
Default=True
RegKey1=HKCU\Software\grigsoft.com\Compare It!\Combos
RegKey2=HKCU\Software\grigsoft.com\Compare It!\dirs
RegKey3=HKCU\Software\grigsoft.com\Compare It!\options|Recent0
RegKey4=HKCU\Software\grigsoft.com\Compare It!\options|Recent1
RegKey5=HKCU\Software\grigsoft.com\Compare It!\options|Recent2
RegKey6=HKCU\Software\grigsoft.com\Compare It!\options|Recent3
RegKey7=HKCU\Software\grigsoft.com\Compare It!\options|Recent4
RegKey8=HKCU\Software\grigsoft.com\Compare It!\options|Recent5
RegKey9=HKCU\Software\grigsoft.com\Compare It!\options|Recent6
RegKey10=HKCU\Software\grigsoft.com\Compare It!\options|Recent7
RegKey11=HKCU\Software\grigsoft.com\Compare It!\options|Recent8
RegKey12=HKCU\Software\grigsoft.com\Compare It!\options|Recent9
RegKey13=HKCU\Software\grigsoft.com\Compare It!\options|Recent10
[*Config.msi Folder]
LangSecRef=3025
Default=True
DetectFile=%windir%\system32\msiexec.exe
FileKey1=%systemdrive%\Config.msi|*.*|RECURSE
[*ConTEXT]
LangSecRef=3021
Detect=HKCU\Software\Eden\ConTEXT
Default=True
Regkey1=HKCU\Software\Eden\ConTEXT\FileHistory
Regkey2=HKCU\Software\Eden\ConTEXT\FindHistory
[*ConvertXToDVD]
LangSecRef=3023
Detect=HKCU\Software\VSO\ConvertXToDVD
Default=True
FileKey1=%userprofile%\Application Data\Vso|*.log
[Copernic Desktop Search]
LangSecRef=3021
Detect=HKCU\Software\Copernic\DesktopSearch2
Default=True
RegKey1=HKCU\Software\Copernic\DesktopSearch2\Config\SearchHistory
[*CounterSpy]
LangSecRef=3024
Detect=HKLM\SOFTWARE\Sunbelt Software\CounterSpy
Default=True
FileKey1=%allusersprofile%\Application Data\Sunbelt Software\CounterSpy\Logs|*.*
[*Creative Pro Proteus VX]
LangSecRef=3023
Detect=HKCU\Software\Creative Professional\Proteus VX
Default=True
RegKey1=HKCU\Software\Creative Professional\Proteus VX VSTi\Recent File List
[*CuteHTML 2.3]
LangSecRef=3024
Detect=HKCU\Software\GlobalSCAPE\CuteHTML\2.3
Default=True
RegKey1=HKCU\Software\GlobalSCAPE\CuteHTML\2.3\Recent File List
[*DC++]
LangSecRef=3022
DetectFile=%ProgramFiles%\DC++\DCPlusPlus.exe
Default=True
FileKey1=%ProgramFiles%\DC++|files.xml.bz2
FileKey2=%ProgramFiles%\DC++\FileLists|*.*
FileKey3=%ProgramFiles%\DC++\Logs|*.*
[*Dependency Walker]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Dependency Walker
Default=True
RegKey1=HKCU\Software\Microsoft\Dependency Walker\Recent File List
[*DivX Movies Cache]
; Will remove all saved streamed videos!
LangSecRef=3023
Detect=HKLM\Software\DivXNetworks
Default=False
FileKey1=%userprofile%\My Documents\My Videos\DivX Movies|*.*|RECURSE
RegKey1=HKCU\Software\DivXNetworks\DivXBrowserPlugin|cacheEntry1
RegKey2=HKCU\Software\DivXNetworks\DivXBrowserPlugin|cacheEntry2
RegKey3=HKCU\Software\DivXNetworks\DivXBrowserPlugin|cacheEntry3
RegKey4=HKCU\Software\DivXNetworks\DivXBrowserPlugin|cacheEntry4
RegKey5=HKCU\Software\DivXNetworks\DivXBrowserPlugin|cacheEntry5
RegKey6=HKCU\Software\DivXNetworks\DivXBrowserPlugin|cacheEntry6
[*Dogpile Toolbar]
LangSecRef=3022
Detect=HCKU\Software\Infospace\DogpileToolbar
Default=True
RegKey1=HCKU\Software\Infospace\DogpileToolbar\History|1-terms
[*Dup Detector]
LangSecRef=3023
Detect=HKCU\Software\Prismatic Software\PhotoBatch
Default=True
RegKey1=HKCU\Software\Prismatic Software\PhotoBatch\Dups|LastBatFile
RegKey2=HKCU\Software\Prismatic Software\PhotoBatch\Dups|LastFold
RegKey3=HKCU\Software\Prismatic Software\PhotoBatch\Dups|LastSecFold
RegKey4=HKCU\Software\Prismatic Software\PhotoBatch\Dups|LastSingleFold
[*DU meter]
LangSecRef=3022
Detect=HKCU\SOFTWARE\Hagel\DU Meter
Default=True
FileKey1=%allusersprofile%\Application Data\Hagel Technologies\DU Meter|*.csv
[*DVD Shrink (Analysis Results)]
; Note: Each time you use this you'll have to agree to the DVD Shrink license.
LangSecRef=3023
Detect=HKCU\Software\DVD Shrink
Default=False
FileKey1=%allusersprofile%\Application Data\DVD Shrink|*.*
[*DVDx]
LangSecRef=3023
Detect=HKCU\Software\DVDx
Default=True
RegKey1=HKCU\Software\DVDx\LastDir
RegKey2=HKCU\Software\DVDx\LastOutput
FileKey1=%ProgramFiles%\DVDx|*.tmp
[*Easy CD-DA Extractor]
LangSecRef=3024
Default=True
Detect=HKCU\Software\Poikosoft\Easy CD-DA Extractor 8
RegKey1=HKCU\Software\Poikosoft\Easy CD-DA Extractor 8|k80
RegKey2=HKCU\Software\Poikosoft\Easy CD-DA Extractor 8|k81
RegKey3=HKCU\Software\Poikosoft\Easy CD-DA Extractor 8|k8c
RegKey4=HKCU\Software\Poikosoft\Easy CD-DA Extractor 8|k91
RegKey5=HKCU\Software\Poikosoft\Easy CD-DA Extractor 8|k92
[*eBay Toolbar]
LangSecRef=3022
DetectFile=%ProgramFiles%\eBay\eBay Toolbar2\eBayTBDaemon.exe
Default=True
RegKey1=HKCU\Software\eBay\eBayToolbar\History
RegKey2=HKCU\Software\eBay\eBayToolbar\RecentSearches
FileKey1=%ProgramFiles%\eBay\eBay Toolbar2|toolbar.log
FileKey2=%ProgramFiles%\eBay\eBay Toolbar2|eBayDaemon.log
[*Effective File Search]
LangSecRef=3021
DetectFile=%ProgramFiles%\efs\search.exe
Default=True
FileKey1=%ProgramFiles%\efs|cblist*.dat
[*EmEditor]
LangSecRef=3024
Detect=HKCU\Software\EmSoft\EmEditor v3
Default=True
RegKey1=HKCU\Software\EmSoft\EmEditor v3\Recent File List
RegKey2=HKCU\Software\EmSoft\EmEditor v3\Recent Folder List
RegKey3=HKCU\Software\EmSoft\EmEditor v3\Recent Font List
[*Eraser (Log)]
LangSecRef=3024
Detect=HKCU\Software\Heidi Computers Ltd\Eraser\5.5
Default=True
FileKey1=%ProgramFiles%\Eraser|schedlog.txt
[*ESPN Motion]
LangSecRef=3023
Detect=HKCU\SOFTWARE\Disney\DIGStream
Default=True
FileKey1=%allusersprofile%\Application Data\DIGStream\ESPNMotion|*.wmv
FileKey2=%allusersprofile%\Application Data\DIGStream\ESPNMotion|*.tmp
[*ESPN Motion Advertisements]
LangSecRef=3023
Default=True
FileKey1=%allusersprofile%\Application Data\DIGStream\ESPNMotion|ad_*.wmv
FileKey2=%allusersprofile%\Application Data\DIGStream\ESPNMotion|*promo*.wmv
FileKey3=%allusersprofile%\Application Data\DIGStream\ESPNMotion|*commercial*.wmv
FileKey4=%allusersprofile%\Application Data\DIGStream\ESPNMotion|*motionbumper*.wmv
[*Essential NetTools 3]
LangSecRef=3022
Detect=HKCU\Software\ENT3
Default=True
RegKey1=HKCU\Software\ENT3\Recent
[*ExamDiff]
LangSecRef=3024
Detect=HKCU\Software\PrestoSoft\ExamDiff
Default=True
RegKey1=HKCU\Software\PrestoSoft\ExamDiff\Recent Left Files
RegKey2=HKCU\Software\PrestoSoft\ExamDiff\Recent Right Files
RegKey3=HCKU\Software\PrestoSoft\ExamDiff\Settings|File 1
RegKey4=HCKU\Software\PrestoSoft\ExamDiff\Settings|File 2
[*ExamDiff Pro]
LangSecRef=3024
Detect=HKCU\Software\PrestoSoft\ExamDiff Pro
Default=True
RegKey1=HKCU\Software\PrestoSoft\ExamDiff Pro\Recent Left Files
RegKey2=HKCU\Software\PrestoSoft\ExamDiff Pro\Recent Right Files
RegKey3=HCKU\Software\PrestoSoft\ExamDiff Pro\Settings|File 1
RegKey4=HCKU\Software\PrestoSoft\ExamDiff Pro\Settings|File 2
[*Excel Viewer]
LangSecRef=3021
Detect=HKCU\Software\Microsoft\Office\11.0\Excel Viewer\Recent Files
Default=True
RegKey1=HKCU\Software\Microsoft\Office\11.0\Excel Viewer\Recent Files
[*Exifer]
LangSecRef=3021
Detect=HKCU\Software\Exifer
Default=True
RegKey1=HKCU\Software\Exifer\Browse\History
[*ExifPro]
LangSecRef=3023
Detect=HKCU\Software\MKowalski\ExifPro
Default=False
RegKey1=HKCU\Software\MKowalski\ExifPro\1.0\RecentPaths
RegKey2=HKCU\Software\MKowalski\ExifPro\1.0\ResizeDlg\RecentDestPaths
RegKey3=HKCU\Software\MKowalski\ExifPro\1.0\HTMLAlbumGen\RecentDestPaths
RegKey4=HKCU\Software\MKowalski\ExifPro\1.0\Browser\View 0|LastPath
FileKey1=%allusersprofile%\Application Data\MiK\ExifPro|Cache*
[*FARManager]
LangSecRef=3021
Detect=HKCU\Software\Far\
Default=True
RegKey1=HKCU\Software\Far\SavedDialogHistory
RegKey2=HKCU\Software\Far\SavedFolderHistory
RegKey3=HKCU\Software\Far\SavedHistory
RegKey4=HKCU\Software\Far\SavedViewHistory
[*FeedDemon]
LangSecRef=3022
Detect=HKCU\Software\Bradbury\FeedDemon\1.0
Default=True
RegKey1=HKCU\Software\Bradbury\FeedDemon\1.0\SavedLists\TypedURLs
RegKey2=HKCU\Software\Bradbury\FeedDemon\1.0\SavedLists\TabbedBrowserUrls
[*FileLocator Pro]
LangSecRef=3024
Detect=HKCU\Software\Mythicsoft\FileLocatorPro
Default=True
RegKey1=HKCU\Software\Mythicsoft\FileLocatorPro\RecentContains
RegKey2=HKCU\Software\Mythicsoft\FileLocatorPro\RecentFileName
RegKey3=HKCU\Software\Mythicsoft\FileLocatorPro\RecentFolders
[*FlashFXP]
LangSecRef=3022
DetectFile=%ProgramFiles%\FlashFXP\flashfxp.exe
Default=True
FileKey1=%ProgramFiles%\FlashFXP|quick.dat
[*FlashGet]
LangSecRef=3022
Detect=HKCU\Software\JetCar
Default=True
RegKey1=HKCU\Software\JetCar\JetCar|Recent File List
FileKey1=%programfiles%\FlashGet|Default.bk*
FileKey2=%programfiles%\FlashGet|Default.jcd
FileKey3=%programfiles%\FlashGet|Default.jcd.bak
[*Foobar2000 (Crash Log)]
LangSecRef=3023
Detect=HKLM\Software\foobar2000
Default=True
FileKey1=%programfiles%\foobar2000|failure.txt
[*Forward Observer]
LangSecRef=3021
DetectFile=%Program Files%\AAForwardObserver\AAForwardObserver.exe
Default=True
FileKey1=%Program Files%\AAForwardObserver|FO.log
[*Foxit PDF Editor]
LangSecRef=3021
DetectFile=%ProgramFiles%\Foxit Software\PDF Editor\PDFEdit.exe
Default=True
RegKey1=HKCU\Software\Foxit Software Company\Foxit PDF Editor|Recent File List
[*Free Download Manager]
LangSecRef=3022
DetectFile=%ProgramFiles%\Free Download Manager\fdm.exe
Default=True
RegKey1=HKCU\Software\FreeDownloadManager.ORG\Free Download Manager\Settings\Find","What
RegKey2=HKCU\Software\FreeDownloadManager.ORG\Free Download Manager\Settings\View","LastDldMoveToFolder
FileKey1=%userprofile%\Application Data\Free Download Manager|downloads.sav
FileKey2=%userprofile%\Application Data\Free Download Manager|uploads.1.sav
FileKey3=%userprofile%\Application Data\Free Download Manager|dlmgrsi.sav
FileKey4=%userprofile%\Application Data\Free Download Manager|downloads.his.sav
FileKey5=%userprofile%\Application Data\Free Download Manager|history.sav
FileKey6=%userprofile%\Application Data\Free Download Manager|sites.sav
FileKey7=%userprofile%\Application Data\Free Download Manager|spider.sav
FileKey8=%userprofile%\Application Data\Free Download Manager|schedules.sav
FileKey9=%userprofile%\Application Data\Free Download Manager|mctasks.sav
FileKey10=%userprofile%\Application Data\Free Download Manager|*.bak
[*Free Registry Defrag]
; Removes registry backups after compressing the registry.
LangSecRef=3024
Detect=HKCU\Software\Local AppWizard-Generated Applications\RegDefrag
Default=True
FileKey1=%WinDir%\$regcmp$|*.*
[*FrostWire]
LangSecRef=3022
DetectFile=%ProgramFiles%\FrostWire\FrostWire.exe
Default=True
FileKey1=%userprofile%\Application Data\FrostWire|fileurns.cache
FileKey2=%userprofile%\Application Data\FrostWire|createtimes.cache
FileKey3=%userprofile%\Application Data\FrostWire|responses.cache
FileKey4=%userprofile%\Application Data\FrostWire|ttree.cache
FileKey5=%userprofile%\Application Data\FrostWire|gnutella.net
FileKey6=%userprofile%\Application Data\FrostWire|ttroot.cache
FileKey7=%userprofile%\Application Data\FrostWire|fileurns.bak
FileKey8=%userprofile%\Application Data\FrostWire|checkandupdate.txt
[*FTP Accounts]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Ftp
Default=True
RegKey1=HKCU\Software\Microsoft\Ftp\Accounts
[*Game Maker 4]
LangSecRef=3021
Detect=HKCU\Software\Game Maker 4
Default=True
RegKey1=HKCU\Software\Game Maker 4\Preferences|Recent0
RegKey2=HKCU\Software\Game Maker 4\Preferences|Recent1
RegKey3=HKCU\Software\Game Maker 4\Preferences|Recent2
RegKey4=HKCU\Software\Game Maker 4\Preferences|Recent3
RegKey5=HKCU\Software\Game Maker 4\Preferences|GameDir
[*Game Maker 5]
LangSecRef=3021
Detect=HKCU\Software\Game Maker\Version 5
Default=True
RegKey1=HKCU\Software\Game Maker\Version 5\Preferences|Recent0
RegKey2=HKCU\Software\Game Maker\Version 5\Preferences|Recent1
RegKey3=HKCU\Software\Game Maker\Version 5\Preferences|Recent2
RegKey4=HKCU\Software\Game Maker\Version 5\Preferences|Recent3
RegKey5=HKCU\Software\Game Maker\Version 5\Preferences|Recent4
RegKey6=HKCU\Software\Game Maker\Version 5\Preferences|Recent5
RegKey7=HKCU\Software\Game Maker\Version 5\Preferences|Recent6
RegKey8=HKCU\Software\Game Maker\Version 5\Preferences|Recent7
RegKey9=HKCU\Software\Game Maker\Version 5\Preferences|GameDir
[*Game Maker 6]
LangSecRef=3021
Detect=HKCU\Software\Game Maker\Version 6
Default=True
RegKey1=HKCU\Software\Game Maker\Version 6\Preferences|Recent0
RegKey2=HKCU\Software\Game Maker\Version 6\Preferences|Recent1
RegKey3=HKCU\Software\Game Maker\Version 6\Preferences|Recent2
RegKey4=HKCU\Software\Game Maker\Version 6\Preferences|Recent3
RegKey5=HKCU\Software\Game Maker\Version 6\Preferences|Recent4
RegKey6=HKCU\Software\Game Maker\Version 6\Preferences|Recent5
RegKey7=HKCU\Software\Game Maker\Version 6\Preferences|Recent6
RegKey8=HKCU\Software\Game Maker\Version 6\Preferences|Recent7
RegKey9=HKCU\Software\Game Maker\Version 6\Preferences|GameDir
[*Game Maker 7]
LangSecRef=3021
Detect=HKCU\Software\Game Maker\Version 7
Default=True
RegKey1=HKCU\Software\Game Maker\Version 7\Preferences|Recent0
RegKey2=HKCU\Software\Game Maker\Version 7\Preferences|Recent1
RegKey3=HKCU\Software\Game Maker\Version 7\Preferences|Recent2
RegKey4=HKCU\Software\Game Maker\Version 7\Preferences|Recent3
RegKey5=HKCU\Software\Game Maker\Version 7\Preferences|Recent4
RegKey6=HKCU\Software\Game Maker\Version 7\Preferences|Recent5
RegKey7=HKCU\Software\Game Maker\Version 7\Preferences|Recent6
RegKey8=HKCU\Software\Game Maker\Version 7\Preferences|Recent7
RegKey9=HKCU\Software\Game Maker\Version 7\Preferences|GameDir
[*Genie Backup Manager Pro 6.0]
LangSecRef=3024
DetectFile=%userprofile%\Application Data\Genie-soft\GBMPro6
Default=True
FileKey1=%userprofile%\Application Data\Genie-soft\GBMPro6\logs|*.*
[*GIANT AntiSpyware]
LangSecRef=3024
DetectFile=%ProgramFiles%\GIANT Company Software\GIANT AntiSpyware\GIANTAntiSpywareMain.exe
Default=True
FileKey1=%ProgramFiles%\GIANT Company Software\GIANT AntiSpyware|errors.log
FileKey2=%ProgramFiles%\GIANT Company Software\GIANT AntiSpyware|tracksEraser.log
FileKey3=%ProgramFiles%\GIANT Company Software\GIANT AntiSpyware|cleaner.log
[*GIMP]
LangSecRef=3021
Default=true
Detect=HKLM\SOFTWARE\Classes\GIMP-2.0-gbr\shell
filekey1=%userprofile%\.thumbnails\normal|*.*
filekey2=%userprofile%\.gimp-2.4|documents
[*Go!Zilla]
LangSecRef=3022
Detect=%Program Files%\Go!Zilla
Default=True
FileKey1=%ProgramFiles%\Go!Zilla\golog.htm
FileKey2=%ProgramFiles%\Go!Zilla\leech.hst
FileKey3=%ProgramFiles%\Go!Zilla\download.log
[*Google Calendar Sync]
LangSecRef=3022
Detect=HKCU\Software\Google\Google Calendar Sync
Default=True
FileKey1=%userprofile%\Application Data\Google\Google Calendar Sync\logs|*.log
[*Google Talk]
LangSecRef=3022
DetectFile=%ProgramFiles%\Google\Google Talk
Default=False
FileKey1=%userprofile%\Local Settings\Application Data\Google\Google Talk\status|*.txt
FileKey2=%userprofile%\Local Settings\Application Data\Google\Google Talk\chatlogs|*.log
[*Google Video Player]
LangSecRef=3023
DetectFile=%ProgramFiles%\Google\Google Video Player\GoogleVideoPlayer.exe
Default=True
RegKey1=HKCU\Software\Google\Google Video Player\MRUList
[*GridinSoft Notepad]
LangSecRef=3021
Detect=HKCU\Software\GridinSoft\Notepad3
Default=True
RegKey1=HKCU\Software\GridinSoft\Notepad3\Files
RegKey2=HKCU\Software\GridinSoft\Notepad3\Search|ReplaceTextHistory
RegKey3=HKCU\Software\GridinSoft\Notepad3\Search|TextHistory
[*Grisoft AVG 7.5]
LangSecRef=3024
Detect=HKLM\SOFTWARE\Grisoft\Avg7
Default=True
FileKey1=%allusersprofile%\Application Data\Grisoft|*.AVG
FileKey2=%allusersprofile%\Application Data\Grisoft\Avg7Data|*.AVG
FileKey3=%allusersprofile%\Application Data\Grisoft\Avg7Data|*.log
FileKey4=%allusersprofile%\Application Data\Grisoft\Avg7Data\upd7bin|*.*
FileKey5=%allusersprofile%\Application Data\Grisoft\Avg7Data\$history|*.*
FileKey6=%allusersprofile%\Application Data\Grisoft\Avg7Data\avg7upd|*.log
FileKey7=%windir%\All Users\Application Data\Grisoft|*.AVG
FileKey8=%windir%\All Users\Application Data\Grisoft\Avg7Data|*.AVG
FileKey9=%windir%\All Users\Application Data\Grisoft\Avg7Data\upd7bin|*.*
FileKey10=%windir%\All Users\Application Data\Grisoft\Avg7Data\avg7upd|$history
FileKey11=%windir%\All Users\Application Data\Grisoft\Avg7Data\avg7upd|*.log
FileKey12=%windir%\All Users\Application Data\Grisoft\Avg7Data|*.log
FileKey13=%windir%\Application Data\AVG7\Log|*.log
[*GroupWise Messenger]
LangSecRef=3021
Detect=HKCU\Software\Novell\Messenger
Default=True
FileKey1=%userprofile%\Local Settings\Application Data\Novell\GroupWise Messenger\history\%user%|*.*
[*GSpot]
LangSecRef=3024
Detect=HKCU\Software\GSpot Appliance Corp
Default=True
RegKey1=HKCU\Software\GSpot Appliance Corp\GSpot\v2.6 Settings|LastMediaFile
[*HDD Thermometer]
LangSecRef=3024
Detect=HKCU\SOFTWARE\RSD Software, Inc.\HDD Thermometer
Default=True
FileKey1=%allusersprofile%\Application Data\HDD Thermometer|*.log
FileKey2=%allusersprofile%\Application Data\HDD Thermometer\logs|*.log
[*HitManPro]
LangSecRef=3024
DetectFile=%ProgramFiles%\Hitman Pro\hitmanpro2.exe
Default=True
FileKey1=%ProgramFiles%\Hitman Pro\logs|*.htm
FileKey2=%ProgramFiles%\Hitman Pro\updates|*.*
FileKey3=%ProgramFiles%\Hitman Pro\downloads|*.*
[*HostsMan]
LangSecRef=3024
DetectFile=%ProgramFiles%\HostsMan\hm.exe
Default=True
FileKey1=%appdata%\abelhadigital.com\HostsServer|block2.log
FileKey2=%appdata%\abelhadigital.com\HostsServer|block1.log
[*Hotbar 3.0]
LangSecRef=3022
Detect=HKCU\Software\Hotbar\
Default=True
RegKey1=HKCU\Software\Hotbar\hotbar\ImagesHistory
FileKey1=%ProgramFiles%\Hotbar\v3.0\dynamic|*.*|RECURSE
FileKey2=%ProgramFiles%\Hotbar\v3.0\static|*.*
[*HP Photosmart Premier]
LangSecRef=3021
Detect=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\HP Photo & Imaging
Default=True
FileKey1=%userprofile%\Local Settings\Application Data\HP\Digital Imaging\cache|*.*
[*HxD Hexeditor]
LangSecRef=3021
Detect=HKCU\Software\Mael\HxD
Default=True
RegKey1=HKCU\Software\Mael\HxD\History Lists\Recent Files
[*IconCool Editor]
LangSecRef=3021
DetectFile=%ProgramFiles%\IconCoolEditor\IconCooleditor.exe
Default=True
FileKey1=%ProgramFiles%\IconCoolEditor|IconFileList.src
FileKey2=%ProgramFiles%\IconCoolEditor|Recentlyused.src
[*IdeaSoft Scrapbooks Plus 1.0]
LangSecRef=3021
Detect=HKCU\Software\IdeaSoft\Scrapbooks Plus\1.0
Default=True
RegKey1=HKCU\Software\IdeaSoft\Scrapbooks Plus\1.0\Recent File List
[*IE7pro]
LangSecRef=3024
Detect=HKCU\Software\IE7pro
Default=True
RegKey1=HKCU\Software\IE7pro\ClosedTabs
[*IE Toy]
LangSecRef=3024
Detect=HKCU\Software\MySoftware\IEToy
Default=True
FileKey1=%ProgramFiles%\IE Toy\Data|history
FileKey2=%ProgramFiles%\IE Toy\Data|history_ad
RegKey1=HKCU\Software\MySoftware\IEToy|FRAGS_ad
RegKey2=HKCU\Software\MySoftware\IEToy|FRAGS_popup
[*ImgBurn]
LangSecRef=3021
Detect=HKCU\Software\ImgBurn
Default=True
FileKey1=%appdata%\ImgBurn\Log Files|*.*
FileKey2=%appdata%\ImgBurn\IBG Files|*.*
RegKey1=HKCU\Software\ImgBurn|ISOBUILD_RecentFiles_Destination
RegKey2=HKCU\Software\ImgBurn|ISOBUILD_RecentFiles_Source
RegKey3=HKCU\Software\ImgBurn|ISOWRITE_RecentFiles_Source
[*Inno Setup]
LangSecRef=3021
Detect=HKCU\Software\Jordan Russell\Inno Setup
Default=True
RegKey1=HKCU\Software\Jordan Russell\Inno Setup\ScriptFileHistoryNew
[*InstallShield Professional]
LangSecRef=3021
Detect=HKCU\Software\InstallShield\InstallShield Professional
Default=True
RegKey1=HKCU\Software\InstallShield\InstallShield Professional\6.0\IsCabVu|MRU1
RegKey2=HKCU\Software\InstallShield\InstallShield Professional\6.0\IsCabVu|MRU2
RegKey3=HKCU\Software\InstallShield\InstallShield Professional\6.0\IsCabVu|MRU3
RegKey4=HKCU\Software\InstallShield\InstallShield Professional\6.0\IsCabVu|MRU4
[*Internet Download Manager]
LangSecRef=3022
Detect=HKLM\SOFTWARE\Internet Download Manager
Default=True
FileKey1=%Appdata%\IDM\UrlHistory.txt
FileKey2=%Appdata%\IDM\UrlHistory2.txt
[*Internet Logs]
LangSecRef=3025
DetectFile=%windir%\Internet Logs
Default=True
FileKey1=%windir%\Internet Logs|*.dmp
FileKey2=%windir%\Internet Logs|*.log
FileKey3=%windir%\Internet Logs|*.tmp
FileKey4=%windir%\Internet Logs|*.zip
[*IsoBuster]
LangSecRef=3023
Detect=HKCU\Software\Smart Projects\IsoBuster
Default=True
RegKey1=HKCU\Software\Smart Projects\IsoBuster\RecentImages
[*iSysCleaner]
LangSecRef=3024
DetectFile=%ProgramFiles%\Utils\iSysCleaner\iSysCleaner.exe
Default=True
FileKey1=%ProgramFiles%\Utils\iSysCleaner\traces|*.*
[*Jetico Personal Firewall (Logs)]
LangSecRef=3022
Detect=HKLM\Software\Jetico\Personal Firewall
Default=False
FileKey1=%ProgramFiles%\Jetico\Jetico Personal Firewall|firewall*.log
[*KMPlayer]
LangSecRef=3023
Detect=HKCU\Software\KMPlayer
Default=True
RegKey1=HKCU\Software\KMPlayer\KMP2.0|LastFileName
RegKey2=HKCU\Software\KMPlayer\WideAlbum\(Default Album)
[*Koffix Blocker]
LangSecRef=3024
DetectFile=%ProgramFiles%\Koffix Blocker\Koffix.exe
Default=True
FileKey1=%userprofile%\My Documents\My Koffix Blocker Logs|*.*
[*LimeWire]
LangSecRef=3022
DetectFile=%ProgramFiles%\LimeWire\LimeWire.exe
Default=True
FileKey1=%userprofile%\Incomplete|*.*|RECURSE
FileKey2=%userprofile%\Application Data\LimeWire|fileurns.cache
FileKey3=%userprofile%\Application Data\LimeWire|createtimes.cache
FileKey4=%userprofile%\Application Data\LimeWire|responses.cache
FileKey5=%userprofile%\Application Data\LimeWire|ttree.cache
FileKey6=%userprofile%\Application Data\LimeWire|gnutella.net
[*LogMeIn]
LangSecRef=3022
DetectFile=%ProgramFiles%\Logmein\x86\LogMeIn.exe
Default=False
FileKey1=%ProgramFiles%\Logmein|LMI*.log
[*Macromedia Shockwave 8]
LangSecRef=3023
Detect=HKCU\Software\Macromedia\Shockwave 8
Default=True
RegKey1=Software\Macromedia\Shockwave 8\movies
[*Macromedia Shockwave 10]
LangSecRef=3023
Detect=HKCU\Software\Macromedia\Shockwave 10
Default=True
RegKey1=Software\Macromedia\Shockwave 10\movies
[*MagicISO]
LangSecRef=3021
Detect=HKCU\Software\MagicISO
Default=True
RegKey1=HKCU\Software\MagicISO\Reopen
[Malwarebytes' Anti Malware]
LangSecRef=3024
DetectFile=%ProgramFiles%\Malwarebytes' Anti-Malware\mbam.exe
Default=False
FileKey1=%appdata%\Malwarebytes\Malwarebytes' Anti-Malware\Logs|*.txt
FileKey2=%appdata%\Malwarebytes\Malwarebytes' Anti-Malware\Quarantine|*.*
[*Maxthon Browser 2]
LangSecRef=3022
DetectFile=%ProgramFiles%\Maxthon2\Maxthon.exe
Default=True
FileKey1=%ProgramFiles%\Maxthon2\Temp|*.*
[*McAfee SiteAdvisor]
LangSecRef=3024
DetectFile=%appdata%\SiteAdvisor
Default=True
FileKey1=%appdata%\SiteAdvisor|asserts.txt
FileKey2=%allusersdata%\SiteAdvisor|*.log
FileKey3=%commonappdata%\McAfee\MCLOGS\MISP\SAService|SAService*.log
[*MediaMonkey]
LangSecRef=3023
DetectFile=%ProgramFiles%\MediaMonkey\MediaMonkey.exe
Default=True
FileKey1=%userprofile%\Local Settings\Temp|*.*|RECURSE
FileKey2=%userprofile%\My Documents\My Music\MediaMonkey|MediaMonkey.m3u
FileKey3=%userprofile%\My Documents\My Music\MediaMonkey\Previews|*.*|RECURSE
[*Media Player Classic]
LangSecRef=3023
Detect=HKLM\Software\Gabest\Media Player Classic
Default=True
FileKey1=%appdata%\Media Player Classic|default.mpcpl
RegKey1=HKCU\Software\Gabest\Media Player Classic\Recent File List
RegKey2=HKCU\Software\Gabest\Media Player Classic\Recent Dub List
RegKey3=HKCU\Software\Gabest\Media Player Classic\Capture|FileName
[*Messenger Plus! Live (Logs)]
LangSecRef=3022
Detect=HKCU\Software\Patchou
Default=True
FileKey1=%userprofile%\My Documents\My Chat Logs|*.*|RECURSE
[*Microangelo]
LangSecRef=3021
Detect=HKCU\Software\Impact\Microangelo
Default=True
RegKey1=HKCU\Software\Impact\Microangelo\Animator\MRU List
RegKey2=HKCU\Software\Impact\Microangelo\Librarian\MRU List
RegKey3=HKCU\Software\Impact\Microangelo\Studio\MRU List
[*Microangelo 6]
LangSecRef=3021
Detect=HKCU\Software\Eclipsit\Microangelo\Toolset 6
Default=True
RegKey1=HKCU\Software\Eclipsit\Microangelo\Toolset 6\Animator\MRU List
RegKey2=HKCU\Software\Eclipsit\Microangelo\Toolset 6\Librarian\MRU List
RegKey3=HKCU\Software\Eclipsit\Microangelo\Toolset 6\Studio\MRU List
[*mIRC]
LangSecRef=3022
Detect=HKCU\Software\mIRC\
Default=True
DectectFile=%ProgramFiles%\mirc\mIRC.exe
Filekey1=%ProgramFiles%\mirc\logs\|*.*
[*MiTeC DFM Editor]
LangSecRef=3021
Detect=HKCU\Software\MiTeC\DFM Editor
Default=True
RegKey1=HKCU\Software\MiTeC\DFM Editor\5.x\Main\MRUHistory
[*MS Backup (Logs)]
LangSecRef=3025
DetectFile=%SystemRoot%\System32\ntbackup.exe
Default=True
FileKey1=%userprofile%\Local Settings\Application Data\Microsoft\Windows NT\NTBackup\Data|*.log
[*MS Direct Draw]
LangSecRef=3021
Detect=HKCU\Software\Microsoft\DirectDraw
Default=True
RegKey1=HKCU\Software\Microsoft\DirectDraw\MostRecentApplicationName
[*MS Help Workshop]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Microsoft Help Workshop
Default=True
RegKey1=HKCU\Software\Microsoft\Microsoft Help Workshop\Cnt Files
RegKey2=HKCU\Software\Microsoft\Microsoft Help Workshop\Forage Files
RegKey3=HKCU\Software\Microsoft\Microsoft Help Workshop\Hlp Files
RegKey4=HKCU\Software\Microsoft\Microsoft Help Workshop\Hpj Files
RegKey5=HKCU\Software\Microsoft\Microsoft Help Workshop\Map Files
RegKey6=HKCU\Software\Microsoft\Microsoft Help Workshop\Recent File List
[*MS HTML Help Workshop]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\HTML Help Workshop
Default=True
RegKey1=HKCU\Software\Microsoft\HTML Help Workshop\Compressed HTML
RegKey2=HKCU\Software\Microsoft\HTML Help Workshop\Html Titles
RegKey3=HKCU\Software\Microsoft\HTML Help Workshop\Project Files
RegKey4=HKCU\Software\Microsoft\HTML Help Workshop\Recent File List
RegKey5=HKCU\Software\Microsoft\HTML Help Workshop\Settings|LastProject
RegKey6=HKCU\Software\Microsoft\Microsoft HTML Help Image Editor\Folders
RegKey7=HKCU\Software\Microsoft\Microsoft HTML Help Image Editor\Recent File List
[*MS Imaging]
LangSecRef=3024
Detect=HKCU\Software\Kodak\Imaging
Default=True
RegKey1=HKCU\Software\Kodak\Imaging\Recent File List
[*MS Office 2003 Script Editor]
LangSecRef=3021
Detect=HKCU\Software\Microsoft\Office\11.0\MSE
Default=True
RegKey1=HKCU\Software\Microsoft\Office\11.0\MSE|LastLoadedSolution
Regkey2=HKCU\Software\Microsoft\Office\11.0\MSE\FileMRUList
Regkey3=HKCU\Software\Microsoft\Office\11.0\MSE\ProjectMRUList
Regkey4=HKCU\Software\Microsoft\Office\11.0\MSE\SolutionMRUList
[*MS Office Picture Manager]
LangSecRef=3021
Default=True
FileKey1=%LocalAppData%\Microsoft\OIS|OIScatalog.cag
FileKey2=%LocalAppData%\Microsoft\OIS\thumbnails|*.*
[*MS Office Publisher 2003]
LangSecRef=3021
Detect=HKCU\Software\Microsoft\Office\11.0\Publisher
Default=True
RegKey1=HKCU\Software\Microsoft\Office\11.0\Publisher\Recent File List
[*MS PhotoDraw 2000]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\PhotoDraw\1.0
Default=True
RegKey1=HKCU\Software\Microsoft\PhotoDraw\1.0\Recent File List
[*MS SQL Server 2005]
LangSecRef=3021
Detect=HKCU\Software\Microsoft\Microsoft SQL Server\90\Tools\Shell
Default=False
RegKey1=HKCU\Software\Microsoft\Microsoft SQL Server\90\Tools\Shell\FileMRUList
RegKey2=HKCU\Software\Microsoft\Microsoft SQL Server\90\Tools\Shell\ProjectMRUList
[*MS Visual Studio.NET 2003]
LangSecRef=3021
Detect=HKCU\Software\Microsoft\VisualStudio\7.1
Default=True
RegKey1=HKCU\Software\Microsoft\VisualStudio\7.1\ProjectMRUList|File1
RegKey2=HKCU\Software\Microsoft\VisualStudio\7.1\ProjectMRUList|File2
RegKey3=HKCU\Software\Microsoft\VisualStudio\7.1\ProjectMRUList|File3
RegKey4=HKCU\Software\Microsoft\VisualStudio\7.1\ProjectMRUList|File4
RegKey5=HKCU\Software\Microsoft\VisualStudio\7.1\ProjectMRUList|File5
[*MS Visual Studio 2005]
LangSecRef=3021
Detect=HKCU\Software\Microsoft\VisualStudio\8.0
Default=False
RegKey1=HKCU\Software\Microsoft\VisualStudio\8.0\FileMRUList
RegKey2=HKCU\Software\Microsoft\VisualStudio\8.0\ProjectMRUList
[*MS XML Notepad]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\XML Notepad
Default=True
RegKey1=HKCU\Software\Microsoft\XML Notepad\Recent File List
[*MS Windows Wallpaper]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Wallpaper
Default=True
RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Wallpaper\MRU
[*More Windows Explorer]
LangSecRef=3025
Default=True
RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\StreamMRU
[*MP3Gain (Logs)]
LangSecRef=3023
Detect=HKCU\Software\VB and VBA Program Settings\MP3GainAnalysis
Default=True
FileKey1=%ProgramFiles%\MP3Gain|*.log
[*Mp3tag (Log)]
; Removes Mp3tagError.log
LangSecRef=3023
Detect=HKLM\Software\Florian Heidenreich\Mp3tag
Default=True
FileKey1=%appdata%\Mp3tag|Mp3tagError.log
[*MPEG Audio Collection]
LangSecRef=3023
Detect=HKCU\Software\MPEG Audio Collection
Default=True
RegKey1=HKCU\Software\MPEG Audio Collection|LastNameText1
RegKey2=HKCU\Software\MPEG Audio Collection|LastNameText2
RegKey3=HKCU\Software\MPEG Audio Collection|LastNameText3
RegKey4=HKCU\Software\MPEG Audio Collection|LastNameText4
RegKey5=HKCU\Software\MPEG Audio Collection|LastNameText5
RegKey6=HKCU\Software\MPEG Audio Collection|LastNameText6
[*MSConfig]
; Removes the MSConfig.exe ExpandFrom and ExpandTo MRU list after
; using the Expand File feature (aka .cab file extraction tool).
; Also removes MSConfig from autostarting when Windows does after
; you've intentionally disabled a Start Up program.
LangSecRef=3025
Detect=HKLM\Software\Microsoft\Shared Tools\MSConfig
Default=True
RegKey1=HKLM\Software\Microsoft\Shared Tools\MSConfig\ExpandFrom
RegKey2=HKLM\Software\Microsoft\Shared Tools\MSConfig\ExpandTo
RegKey3=HKLM\Software\Microsoft\Windows\CurrentVersion\Run|MSConfig
[*MS Visual Studio.NET 03]
LangSecRef=3021
Default=True
RegKey2=HKCU\Software\Microsoft\VisualStudio\7.1\FileMRUList
RegKey3=HKCU\Software\Microsoft\VisualStudio\7.1|LastLoadedSolution
;ApplicationHistory contains .ini files with all the exe's that were run
FileKey1=%userprofile%\Local Settings\Application Data\ApplicationHistory|*.*|REMOVESELF
[*MS Works Suite 2006]
LangSecRef=3021
Detect= HKCU\Software\Microsoft\Works\8.0
Default=True
RegKey1=HKCU\Software\Microsoft\Works\8.0\Recent File List
[*MUICache]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows\ShellNoRoam\MUICache
Default=False
RegKey1=HKCU\Software\Microsoft\Windows\ShellNoRoam\MUICache\
[*MusicMatch Jukebox]
LangSecRef=3023
Detect=HKLM\Software\MUSICMATCH\MUSICMATCH Jukebox
Default=True
FileKey1=%userprofile%\Local Settings\Application Data\Musicmatch\Jukebox|*.log
FileKey2=%userprofile%\Local Settings\Application Data\Musicmatch\Jukebox|*log.txt
FileKey3=%userprofile%\Local Settings\Application Data\Musicmatch\Jukebox\Cache|*.*
FileKey4=%ProgramFiles%\MUSICMATCH\Musicmatch Jukebox\TEMP|*.*
FileKey5=%ProgramFiles%\MUSICMATCH\Musicmatch Jukebox\MMRadio\Cache|*.*
[*MyToolkit]
LangSecRef=3024
Detect=HKCU\Software\FutureFog\MyToolkit\Options
Default=True
RegKey1=HKCU\Software\FutureFog\MyToolkit\Options|LastUsedFolder
[*NA Framework Agent]
LangSecRef=3021
Detect=HKLM\Software\Network Associates\TVD\Shared Components\Framework
Default=True
FileKey1=%allusersprofile%\Application Data\Network Associates\Common Framework\AgentEvents|*.*
FileKey2=%allusersprofile%\Application Data\McAfee\Common Framework\AgentEvents|*.*
[*neXBC]
LangSecRef=3022
DetectFile=%ProgramFiles%\neXBC\neXBC.exe
Default=True
FileKey1=%ProgramFiles%\neXBC|messages.txt
FileKey2=%ProgramFiles%\neXBC\Logs\Hosted|*.*
FileKey3=%ProgramFiles%\neXBC\Logs\Joined|*.*
[*NoteXpad]
LangSecRef=3021
Detect=HKLM\Software\NoteXpad
Default=True
RegKey1=HKLM\Software\NoteXpad\Recent
[*NSIS]
LangSecRef=3021
Detect=HKLM\Software\NSIS
Default=True
RegKey1=HKLM\Software\NSIS\MRU
[*O&O Defrag]
LangSecRef=3024
Detect=HKCU\Software\O&O\O&O Defrag
Default=True
FileKey1=%userprofile%\My Documents\O&O\O&O Defrag\data\reports|*.*|RECURSE
[*OpenOffice 2.3]
LangSecRef=3021
Detect=HKLM\SOFTWARE\OpenOffice.org\OpenOffice.org\2.3
Default=True
FileKey1=%appdata%\OpenOffice.org2\user\registry\data\org\openoffice\Office|Common.xcu
[*Opera 9 (Classic)]
LangSecRef=3022
DetectFile=%ProgramFiles%\Opera 9\Opera.exe
Default=True
FileKey1=%ProgramFiles%\Opera 9\profile|cookies4.dat
FileKey2=%ProgramFiles%\Opera 9\profile|global.dat
FileKey3=%ProgramFiles%\Opera 9\profile|vlink4.dat
FileKey4=%ProgramFiles%\Opera 9\profile\cache4|*.*
FileKey5=%ProgramFiles%\Opera 9\profile\cacheOp|*.*
[*Orbit Downloader]
LangSecRef=3022
Detect=HKLM\SOFTWARE\Orbit
Default=True
FileKey1=%appdata%\Orbit\|fileinfo.dat
FileKey2=%appdata%\Orbit\|history.dat
FileKey3=%appdata%\Orbit\|unfinish.dat
FileKey4=%appdata%\Orbit\flink|*.*
[*Outlook 2003]
LangSecRef=3021
Detect=HKCU\Software\Microsoft\Office\11.0\Outlook
Default=True
RegKey1=HKCU\Software\Microsoft\Office\11.0\Outlook\Contact|QuickFindMRU
RegKey2=HKCU\Software\Microsoft\Office\11.0\Outlook\Contact|StripSearchMRU
RegKey3=HKCU\Software\Microsoft\Office\11.0\Outlook\Preferences|LocationMRU
RegKey4=HKCU\Software\Microsoft\Office\11.0\Outlook\Office Finder|MRU 1
RegKey5=HKCU\Software\Microsoft\Office\11.0\Outlook\Office Finder|MRU 3
FileKey1=%appdata%\Microsoft\Outlook|Outlook.NK2
[*PDFCreator]
LangSecRef=3024
Detect=HKCU\Software\PDFCreator
Default=True
RegKey1=HKCU\Software\PDFCreator\Program|LastsaveDirectory
[*PDF-XChange Viewer]
LangSecRef=3021
Detect=HKCU\Software\Tracker Software\PDFViewer
Default=True
RegKey1=HKCU\Software\Tracker Software\PDFViewer\Documents\LastOpened
RegKey2=HKCU\Software\Tracker Software\PDFViewer\Documents\LatestView\Bars
RegKey3=HKCU\Software\Tracker Software\PDFViewer\Documents\LatestView\Panes
[*PE Module Explorer]
LangSecRef=3024
Detect=HKCU\Software\Woozle\PE Module Explorer
Default=True
RegKey1=HKCU\Software\Woozle\PE Module Explorer\Recent Files
[*Pelles C]
LangSecRef=3021
Detect=HKCU\Software\Pelle Orinius\PellesC
Default=True
RegKey1=HKCU\Software\Pelle Orinius\PellesC\Recent File List
RegKey2=HKCU\Software\Pelle Orinius\PellesC\Recent Project List
RegKey3=HKCU\Software\Pelle Orinius\PellesC\Recent Search List
[*PerfectDisk 8]
LAngSecRef=3024
Detect=HKCU\Software\Raxco\PerfectDisk\8.0
Default=True
FileKey1=%allusersprofile%\Application Data\Raxco\PerfectDisk\8.0|*.log
[*Phorest]
LangSecRef=3024
Detect=HKCU\Software\FutureFog\Phorest\Options
Default=True
RegKey1=HKCU\Software\FutureFog\Phorest\Options|LastUsedFolder
RegKey2=HKCU\Software\FutureFog\Phorest\Layout|SelectionLeft
RegKey3=HKCU\Software\FutureFog\Phorest\Layout|SelectionTop
RegKey4=HKCU\Software\FutureFog\Phorest\Layout|SelectionWidth
RegKey5=HKCU\Software\FutureFog\Phorest\Layout|SelectionHeight
[*Photo Print Calendar 3.00E Beta]
LangSecRef=3021
Detect=HKLM\SOFTWARE\Computer Institute of Japan, Ltd.\Photo Print Calendar from YOKOHAMA Ver.3.00E beta\3.00E beta
Default=True
[*Photoshop CS Filebrowser]
LangSecRef=3021
Default=True
Detect=HKLM\SOFTWARE\Adobe\Photoshop
FileKey1=%userprofile%\application data\Adobe\FileBrowser\PhotoshopCS|*.*
[*Pok3D]
LangSecRef=3021
DetectFile=%ProgramFiles%\Pok3d\Pok3d.ico
Default=True
FileKey1=%userprofile%\Application Data\Pok3d|*.log
FileKey2=%userprofile%\Application Data\Pok3d|*.dmp
[*PowerDVD]
LangSecRef=3021
DetectFile=%ProgramFiles%\Cyberlink\PowerDVD\PowerDVD.exe
Default=True
FileKey1=%ProgramFiles%\CyberLink\PowerDVD|*.pls
FileKey2=%userprofile%\My Documents\CyberLink\PowerDVD|*.pls
[*PowerZip]
LangSecRef=3024
Detect=HKCU\Software\Trident Software\PowerZip
Default=True
RegKey1=HKCU\Software\Trident Software\PowerZip\Recent File List
[*QuickPAR]
LangSecRef=3024
Detect=HKCU\Software\QuickPar
Default=True
FileKey1=%userprofile%\Local Settings\Application Data\QuickPar|*.*
[*Qwest QuickCare]
LangSecRef=3022
Detect=HKLM\Software\QuickCare
Default=True
FileKey1=%allusersprofile%\Application Data\Support.com|*.tmp|RECURSE
FileKey2=%userprofile%\Local Settings\Application Data\SupportSoft|*.tmp|RECURSE
[*RegAlyzer]
LangSecRef=3024
Detect=HKCU\Software\PepiMK Software\Analysis tools\RegAlyzer
Default=True
RegKey1=HKCU\Software\PepiMK Software\Analysis tools\RegAlyzer|LastKey
RegKey2=HKCU\Software\PepiMK Software\Analysis tools\RegAlyzer|RemoteListHistory
RegKey3=HKCU\Software\PepiMK Software\Analysis tools\RegAlyzer|SearchTerm
[*ReGet Deluxe]
LangSecRef=3022
Detect=HKCU\Software\ReGet Software\ReGetDx
Default=True
FileKey1=%ProgramFiles%\ReGet Deluxe\history|*.*
RegKey1=HKCU\Software\ReGet Software\ReGetDx\FtpExplorer\Hist
RegKey2=HKCU\Software\ReGet Software\ReGetDx\History
RegKey3=HKCU\Software\ReGet Software\ReGetDx\Search\HistFind
[*RegistryFix]
LangSecRef=3024
DetectFile=%ProgramFiles%\RegistryFix\RegistryFix.exe
Default=True
FileKey1=%ProgramFiles%\RegistryFix\logs|*.*
[*Registry Mechanic]
; Removes registry backups after compressing the registry, and only the safe to delete logs
LangSecRef=3024
Detect=HKLM\Software\PCTools\Registry Mechanic
Default=False
FileKey1=%userprofile%|*.rmbak|RECURSE
FileKey2=%userprofile%|*.rrr|RECURSE
FileKey3=%userprofile%|*.rrr.bak|RECURSE
FileKey4=%userprofile%\Local Settings\Application Data\Microsoft\Windows|*.rmbak
FileKey5=%userprofile%\Local Settings\Application Data\Microsoft\Windows|*.rrr
FileKey6=%userprofile%\Local Settings\Application Data\Microsoft\Windows|*.rrr.bak
FileKey7=%allusersprofile%|*.rmbak|RECURSE
FileKey8=%allusersprofile%|*.rrr|RECURSE
FileKey9=%allusersprofile%|*.rrr.bak|RECURSE
FileKey10=%systemdrive%\Documents and Settings\Guest|*.rmbak|RECURSE
FileKey11=%systemdrive%\Documents and Settings\Guest|*.rrr|RECURSE
FileKey12=%systemdrive%\Documents and Settings\Guest|*.rrr.bak|RECURSE
FileKey13=%systemdrive%\Documents and Settings\LocalService|*.rmbak|RECURSE
FileKey14=%systemdrive%\Documents and Settings\LocalService|*.rrr|RECURSE
FileKey15=%systemdrive%\Documents and Settings\LocalService|*.rrr.bak|RECURSE
FileKey16=%systemdrive%\Documents and Settings\NetworkService|*.rmbak|RECURSE
FileKey17=%systemdrive%\Documents and Settings\NetworkService|*.rrr|RECURSE
FileKey18=%systemdrive%\Documents and Settings\NetworkService|*.rrr.bak|RECURSE
FileKey19=%windir%\system32\config|*.rmbak
FileKey20=%windir%\system32\config|*.rrr
FileKey21=%windir%\system32\config|*.rrr.bak
FileKey22=%ProgramFiles%\Registry Mechanic\Log|compactlog.log
FileKey23=%ProgramFiles%\Registry Mechanic\Log|results.log
FileKey24=%ProgramFiles%\Registry Mechanic\Log|scan.log
[*ScanDefrag (Logs)]
LangSecRef=3024
Detect=HKLM\Software\ScanDefrag
Default=True
FileKey1=%SystemDrive%\ScanDefrag|*.log
FileKey2=%SystemDrive%\ScanDefrag\logs|*.txt
[*Second Copy 2000]
LangSecRef=3021
Detect=HKCU\Software\Centered Systems\Second Copy 2000
Default=True
FileKey1=%ProgramFiles%\SecCopy|log.rtf
FileKey2=%ProgramFiles%\SecCopy|log-old.rtf
RegKey1=HKCU\Software\Centered Systems\Second Copy 2000\MRU
[*SecureCRT]
LangSecRef=3021
Detect=HKCU\Software\VanDyke\SecureCRT
Default=True
FileKey1=%appdata%\VanDyke\SecureCRT\Config|Recent File List.ini
FileKey2=%appdata%\VanDyke\SecureCRT\Config|Recent Script List.ini
[*Shareaza]
LangSecRef=3022
DetectFile=%ProgramFiles%\Shareaza\Shareaza.exe
Default=True
FileKey1=%userprofile%\Local Settings\Application Data\Shareaza\Incomplete|*.*
[*SmartFTP]
LangSecRef=3022
Detect=HKCU\Software\SmartFTP
Default=True
FileKey1=%appdata%\SmartFTP\Cache|*.*|RECURSE
FileKey2=%appdata%\SmartFTP|History.dat
[*Smart Installer Maker]
LangSecRef=3024
Detect=HKCU\Software\InstallBuilders\Smart Install Maker
Default=True
RegKey1=HKCU\Software\InstallBuilders\Smart Install Maker\Reopen
[*SoftThinks CD Creator]
LangSecRef=3021
Detect=HKLM\SOFTWARE\SoftThinks
Default=True
FileKey1=%windir%\CREATOR|*.log
[*Soulseek]
LangSecRef=3022
DetectFile=%ProgramFiles%\Soulseek\slsk.exe
Default=True
FileKey1=%ProgramFiles%\Soulseek|search.cfg
[*Soulseek Beta]
LangSecRef=3022
DetectFile=%ProgramFiles%\Soulseek-Test\slsk.exe
Default=True
FileKey1=%ProgramFiles%\Soulseek-Test|search.cfg
[*SpyDefense]
LangSecRef=3024
DetectFile=%ProgramFiles%\Everest Labs\Spydefense\sdc.exe
Default=True
FileKey1=%userprofile%\Application Data\Everest Labs\Spydefense\Backups|BF7.tmp
FileKey2=%userprofile%\Application Data\Everest Labs\Spydefense|SpyDefense.log
FileKey3=%userprofile%\Application Data\Everest Labs\Spydefense|History.ini
FileKey3=%userprofile%\Application Data\Everest Labs\Spydefense|Backups.ini
[*Spyware Doctor]
LangSecRef=3024
Detect=HKCU\Software\PCTools\Spyware Doctor
Default=True
FileKey1=%ProgramFiles%\Spyware Doctor\Log|*.*
[*Spyware Terminator]
LangSecRef=3024
Detect=HKCU\Software\Spyware Terminator
Default=True
FileKey1=%ProgramFiles%\Spyware Terminator\|*.err
FileKey2=%ProgramFiles%\Spyware Terminator\|*.old
FileKey3=%ProgramFiles%\Spyware Terminator\update|*.*
FileKey4=%appdata%\Spyware Terminator\Reports\|*.*
FileKey5=%ProgramFiles%\Spyware Terminator\Clamav\|*.old
[*StarOffice 8]
LangSecRef=3021
DetectFile=%ProgramFiles%\Sun\StarOffice 8\program\soffice.exe
Default=True
FileKey1=%appdata%\StarOffice8\user\registry\data\org\openoffice\Office|Common.xcu
[*STOIK Smart Resizer]
LangSecRef=3023
Detect=HKCU\Software\STOIK Smart Resizer 1.0\STOIK Smart Resizer\Recent File List
Default=True
RegKey1=HKCU\Software\STOIK Smart Resizer 1.0\STOIK Smart Resizer\Recent File List
[*STOIK Video Converter 2]
LangSecRef=3023
Default=True
FileKey1=%appdata%\STOIK\videopak2|*.ini
[*SUPERAntiSpyware (Logs)]
LangSecRef=3024
Detect=HKLM\Software\SUPERAntiSpyware.com\SUPERAntiSpyware
Default=True
FileKey1=%appdata%\SUPERAntiSpyware.com\SUPERAntiSpyware\Logs|*.log
[*Symantec Ghost]
LangSecRef=3024
Detect=HKCU\Software\Symantec\Symantec Ghost
Default=True
RegKey1=HKCU\Software\Symantec\Symantec Ghost\Explorer\Ghost Explorer\Recent File List
[*Synchronize It!]
LangSecRef=3021
Detect=HKCU\Software\grigsoft.com\Synchronize It!
Default=True
RegKey1=HKCU\Software\grigsoft.com\Synchronize It!\Synchronize It!\Combos
RegKey2=HKCU\Software\grigsoft.com\Synchronize It!\Combos
[*Tag&Rename 3]
LangSecRef=3024
Detect=HKCU\Software\Softpointer\Tag&Rename3\Config
Default=True
RegKey1=HKCU\Software\Softpointer\Tag&Rename3\Config|FCurrentFolder
RegKey2=HKCU\Software\Softpointer\Tag&Rename3\Config|FHistoryList
[*Talkback (Crash Reports)]
LangSecRef=3026
Detect=HKLM\SOFTWARE\FullCircle\TalkBack
Default=True
RegKey1=HKLM\SOFTWARE\FullCircle\TalkBack
FileKey1=%userprofile%\Application Data\Talkback\MozillaOrg\Firefox15|*.*|RECURSE
FileKey2=%userprofile%\Application Data\Talkback\MozillaOrg\Firefox2|*.*|RECURSE
FileKey3=%userprofile%\Application Data\Talkback\MozillaOrg\Thunderbird2|*.*|RECURSE
[*TechSmith DubIt]
LangSecRef=3023
Detect=HKCU\Software\TechSmith\DubIt
Default=True
FileKey1=%ProgramFiles%\TechSmith\DubIt|*.gid
RegKey1=HKCU\Software\TechSmith\DubIt\Recent Audio Files
RegKey2=HKCU\Software\TechSmith\DubIt\Recent Video Files
[*TeraCopy]
LangSecRef=3024
Detect=HKCU\Software\Code Sector\TeraCopy
Default=True
RegKey1=HKCU\Software\Code Sector\TeraCopy|LastTargetFolder
FileKey1=%appdata%\TeraCopy|FileList.dat
FileKey2=%appdata%\TeraCopy|Transfer.log
[*The Bat]
LangSecRef=3022
Detect=HKCU\Software\RIT\The Bat!
Default=True
FileKey1=%appdata%\The Bat!\cache|*.*
[*The Cleaner]
LangSecRef=3024
DetectFile=%ProgramFiles%\The Cleaner\cleaner.exe
Default=True
FileKey1=%ProgramFiles%\The Cleaner|logfile.txt
FileKey2=%ProgramFiles%\The Cleaner|moolive.log
FileKey3=%ProgramFiles%\The Cleaner|tca.log
[*The GIMP 2.2]
LangSecRef=3021
DetectFile=%userprofile%\.gimp-2.2\gimprc
Default=True
FileKey1=%userprofile%\.gimp-2.2|documents
[*Tomahawk PDF+]
LangSecRef=3021
Detect=HKCU\Software\NativeWinds\Tomahawk
Default=True
RegKey1=HKCU\Software\NativeWinds\Tomahawk\MRU
[*Total Recorder]
LangSecRef=3023
Detect=HKCU\Software\HighCriteria\TotalRecorder\Recent File List
Default=True
RegKey1=HKCU\Software\HighCriteria\TotalRecorder\Recent File list|File1
RegKey2=HKCU\Software\HighCriteria\TotalRecorder\Recent File list|File2
RegKey3=HKCU\Software\HighCriteria\TotalRecorder\Recent File list|File3
RegKey4=HKCU\Software\HighCriteria\TotalRecorder\Recent File list|File4
RegKey5=HKCU\Software\HighCriteria\TotalRecorder\Recent File list|File5
RegKey6=HKCU\Software\HighCriteria\TotalRecorder\Recent File list|File6
RegKey7=HKCU\Software\HighCriteria\TotalRecorder\Recent File list|File7
RegKey8=HKCU\Software\HighCriteria\TotalRecorder\Recent File list|File8
RegKey9=HKCU\Software\HighCriteria\TotalRecorder\Recent File list|File9
[*Total Uninstall]
LangSecRef=3024
Detect=HKCU\Software\MartS\Total Uninstall
Default=True
FileKey1=%ProgramFiles%\Total Uninstall|Log.txt
FileKey2=%ProgramFiles%\Total Uninstall|*.GID
[*Trillian]
LangSecRef=3024
Detect=HKLM\Software\Clients\IM\Trillian
Default=True
FileKey1=%ProgramFiles%\Trillian\users\default\instantlookup|*.*
FileKey2=%ProgramFiles%\Trillian\users\default\logs|*.*|RECURSE
FileKey3=%ProgramFiles%\Trillian\users\default\buddyicons|*.*|RECURSE
FileKey4=%ProgramFiles%\Trillian\Crash Files|*.*|RECURSE
[*TuneUp Utilities]
LangSecRef=3024
Detect=HKCU\Software\TuneUp
Default=True
FileKey1=%appdata%\TuneUp Software\TuneUp Utilities\Backups|*.rcb
[*TweakNow PowerPack 2005]
LangSecRef=3024
Detect=HKCU\Software\TweakNow PowerPack
Default=True
FileKey1=%ProgramFiles%\TweakNow PowerPack\Backup|*.*
[*Ulead GIF Animator 5.05]
LangSecRef=3024
Detect=HKCU\Software\Ulead Systems\Ulead GIF Animator\5.05
Default=True
RegKey1=HKCU\Software\Ulead Systems\Ulead GIF Animator\5.05\Recent File List
[*UltraISO]
LangSecRef=3024
Detect=HKCU\Software\EasyBoot Systems\UltraISO
Default=True
RegKey1=HKCU\Software\EasyBoot Systems\UltraISO\5.0|Reopen
RegKey2=HKCU\Software\EasyBoot Systems\UltraISO\5.0|a
RegKey3=HKCU\Software\EasyBoot Systems\UltraISO\5.0|b
RegKey4=HKCU\Software\EasyBoot Systems\UltraISO\5.0|c
RegKey5=HKCU\Software\EasyBoot Systems\UltraISO\5.0|d
RegKey6=HKCU\Software\EasyBoot Systems\UltraISO\5.0|e
RegKey7=HKCU\Software\EasyBoot Systems\UltraISO\5.0|f
RegKey8=HKCU\Software\EasyBoot Systems\UltraISO\5.0|g
RegKey9=HKCU\Software\EasyBoot Systems\UltraISO\5.0|h
RegKey10=HKCU\Software\EasyBoot Systems\UltraISO\5.0|i
[*Universal Share Downloader]
LangSecRef=3022
DetectFile=%ProgramFiles%\USDownloader\USDownloader.exe
Default=True
FileKey1=%ProgramFiles%\USDownloader|USDownloader.log
FileKey2=%ProgramFiles%\USDownloader|*.bak
[*UPX Shell]
LangSecRef=3024
Detect=HKCU\Software\ION Tek\UPX Shell
Default=True
RegKey1=HKCU\Software\ION Tek\UPX Shell\3.x|History
[*uTorrent]
LangSecRef=3022
DetectFile=%ProgramFiles%\uTorrent\uTorrent.exe
Default=True
FileKey1=%ProgramFiles%\uTorrent|*.dmp
[*Valve - Steam (Logs)]
LangSecRef=3023
Detect=HKCU\Software\Valve\Steam
Default=True
FileKey1=%ProgramFiles%\Valve\Steam\SteamLogs|*.log
FileKey2=%ProgramFiles%\Valve\Steam|Steam.log
[*Venis IX]
LangSecRef=3021
Detect=HKCU\Software\Spaceblue\Venis IX
Default=True
RegKey1=HKCU\Software\Spaceblue\Venis IX\FileHistory
[*Ventrilo Client]
LangSecRef=3021
Detect=HKCU\Software\Ventrilo
Default=True
FileKey1=%userprofile%\Application Data\Ventrilo|ventrilo.log
FileKey2=%userprofile%\Application Data\Ventrilo\temp|*.*
FileKey3=%userprofile%\Application Data\Ventrilo\recordings|*.*
[*Ventrilo Server]
LangSecRef=3022
DetectFile=%ProgramFiles%\VentSrv\ventrilo_srv.exe
Default=True
FileKey1=%ProgramFiles%\VentSrv|ventrilo_srv.log
[*VideoGet]
LangSecRef=3022
DetectFile=%ProgramFiles%\VideoGet\VideoGet.exe
Default=True
FileKey1=%ProgramFiles%\VideoGet\Temp|*.*
[*VirtualCloneDrive]
LangSecRef=3021
Detect=HKLM\Software\Elaborate Bytes\VirtualCloneDrive
Default=True
RegKey1=HKLM\Software\Elaborate Bytes\VirtualCloneDrive\0
RegKey2=HKCU\Software\Elaborate Bytes\VirtualCloneDrive\LRU
[*VirtualFDD]
LangSecRef=3024
Detect=HKCU\Software\Korbos\VirtualFDD
Default=True
RegKey1=HKCU\Software\Korbos\VirtualFDD\Recent File List
[*Wavosaur (Logs)]
LangSecRef=3023
DetectFile=%ProgramFiles%\Wavosaur\wavosaur.exe
Default=True
FileKey1=%ProgramFiles%\Wavosaur|wavosaur.log
[*Wordweb]
LangSecRef=3021
DetectFile=%ProgramFiles%\WordWeb\wweb32.exe
Default=True
FileKey1=%userprofile%\Application Data\WordWeb|History.txt
[*Winamp]
LangSecRef=3023
Detect=HKCU\Software\Winamp
Default=True
FileKey1=%ProgramFiles%\Winamp|winamp.m3u
FileKey2=%ProgramFiles%\Winamp|winamp.m3u8
FileKey3=%ProgramFiles%\Winamp\Plugins\ml|recent.dat
FileKey4=%ProgramFiles%\Winamp\Plugins\ml\cache|*.*|RECURSE
FileKey5=%userprofile%\Application Data\Winamp|winamp.m3u
FileKey6=%userprofile%\Application Data\Winamp|winamp.m3u8
FileKey7=%userprofile%\Application Data\Winamp\Plugins\ml|recent.dat
FileKey8=%userprofile%\Application Data\Winamp\Plugins\ml\Cache|*.*|RECURSE
[*WinAVI Video Converter (Log)]
LangSecRef=3023
Detect=HKCU\Software\ZjSoft\WinAVI
Default=True
FileKey1=%LocalAppData%\WinAVI|debug.log
[*WinCHM]
LangSecRef=3021
Detect=HKCU\Software\Softany\WinCHM
Default=True
RegKey1=HKCU\Software\Softany\WinCHM|RecentFile1
RegKey2=HKCU\Software\Softany\WinCHM|RecentFile2
RegKey3=HKCU\Software\Softany\WinCHM|RecentFile3
RegKey4=HKCU\Software\Softany\WinCHM|RecentFile4
RegKey5=HKCU\Software\Softany\WinCHM|RecentFile5
RegKey6=HKCU\Software\Softany\WinCHM|RecentFile6
[*WinDiff]
LangSecRef=3024
Detect=HKCU\Software\Microsoft\Windiff
Default=True
RegKey1=HKCU\Software\Microsoft\Windiff|NameLeft
RegKey2=HKCU\Software\Microsoft\Windiff|NameRight
[*WinRAR Comment]
LangSecRef=3024
Detect=HKCU\Software\WinRAR
Default=True
RegKey1=HKCU\Software\WinRAR\General\Info|CommentFile
[*Windows Live Messenger]
LangSecRef=3022
DetectFile=%ProgramFiles%\Windows Live\Messenger\msnmsgr.exe
Default=True
FileKey1=%USERPROFILE%\Application Data\Microsoft\MSN Messenger|*.*|RECURSE
[*Windows ME]
LangSecRef=3025
DetectFile=%windir%\WINFILE.EXE
Default=True
FileKey1=%rootdir%|SCANDISK.LOG
FileKey2=%windir%|*.tmp
FileKey3=%windir%\Application Data|dw.log
FileKey4=%windir%\All Users\Application Data\Spybot - Search & Destroy\Logs|*.*
FileKey5=%windir%\APPLOG|*.LGC
FileKey6=%windir%\Windows Update Setup Files|*.*
[*Windows Update Logs]
LangSecRef=3025
DetectFile=%windir%\SoftwareDistribution\DataStore\Logs
Default=False
FileKey1=%windir%\SoftwareDistribution\DataStore\Logs|*.*
[*WinImage]
LangSecRef=3024
Detect=HKCU\Software\WinImage
Default=True
RegKey1=HKCU\Software\WinImage|File1
RegKey2=HKCU\Software\WinImage|File2
RegKey3=HKCU\Software\WinImage|File3
RegKey4=HKCU\Software\WinImage|File4
RegKey5=HKCU\Software\WinImage|File5
RegKey6=HKCU\Software\WinImage|File6
RegKey7=HKCU\Software\WinImage|File7
RegKey8=HKCU\Software\WinImage|File8
RegKey9=HKCU\Software\WinImage|File9
RegKey10=HKCU\Software\WinImage|PathExtract
[*WinMerge]
LangSecRef=3024
Detect=HKCU\Software\Thingamahoochie\WinMerge\Files
Default=True
RegKey1=HKCU\Software\Thingamahoochie\WinMerge\Files\Ext
RegKey2=HKCU\Software\Thingamahoochie\WinMerge\Files\Left
RegKey3=HKCU\Software\Thingamahoochie\WinMerge\Files\Right
[*WinPatrol]
LangSecRef=3024
Detect=HKCU\Software\BillP Studios\WinPatrol
Default=True
FileKey1=%ProgramFiles%\BillP Studios\WinPatrol|history.txt
[*WinRAR SFX]
LangSecRef=3024
Detect=HKCU\Software\WinRAR SFX
Default=True
RegKey1=HKCU\Software\WinRAR SFX
[*WinWAP]
LangSecRef=3022
Detect=HKCU\Software\Winwap Technologies
Default=True
FileKey1=%userprofile%\WinWAP Temporary Files|*.*
[*WM Recorder 10]
LangSecRef=3023
DetectFile=%ProgramFiles%\WM Recorder 10\WMR.exe
Default=True
FileKey1=%ProgramFiles%\WM Recorder 10|log.txt
FileKey2=%ProgramFiles%\WM Recorder 10|urls.txt
[*WMP (TFC)]
; Transcoded Files Cache
LangSecRef=3023
Detect=HKCU\Software\Microsoft\MediaPlayer\Player
Default=True
FileKey1=%UserProfile%\Local Settings\Application Data\Microsoft\Media Player\Transcoded Files Cache|*.*
[*WS FTP (Pro)]
LangSecRef=3022
Detect=HKCU\Software\Ipswitch\WS_FTP
Default=True
FileKey1=%userprofile%\Application Data\Ipswitch\WS_FTP\Logs|*.*
[*X-Cleaner (free)]
LangSecRef=3024
DetectFile=%ProgramFiles%\X-Cleaner\XCleaner_free.exe
Default=True
FileKey1=%ProgramFiles%\X-Cleaner|XCL_LOG.txt
[*X-Cleaner (full)]
LangSecRef=3024
DetectFile=%ProgramFiles%\X-Cleaner\XCleaner_full.exe
Default=True
[*XFire (Logs)]
LangSecRef=3022
Detect=HKLM\Software\Xfire
Default=True
FileKey1=%userprofile%\Application Data\Xfire\chatlog|*.*|RECURSE
[*XviD Stats]
; Erases the recently used files history.
LangSecRef=3023
Detect=HKCU\Software\GNU\Xvid
Default=True
RegKey1=HKCU\Software\GNU\Xvid|stats
[*Yahoo Messenger (Logs/Cache)]
LangSecRef=3022
Detect=%ProgramFiles%\Yahoo!\Messenger|ypager.log
Default=True
FileKey1=%ProgramFiles%\Yahoo!\Messenger|ypager.log
FileKey2=%ProgramFiles%\Yahoo!\Messenger\Profiles|*.*|RECURSE
FileKey3=%ProgramFiles%\Yahoo!\Messenger\Cache|*.*|RECURSE
FileKey4=%ProgramFiles%\Yahoo!\Messenger\IMVCache|*.*|RECURSE
[*Yahoo! Toolbar]
LangSecRef=3022
Detect=HKCU\Software\Yahoo\Companion
Default=True
RegKey1=HKCU\Software\Yahoo\Companion\SearchHistory
[*YPOPs]
LangSecRef=3021
DetectFile=%ProgramFiles%\YPOPs\ypops.exe
Default=True
FileKey1=%ProgramFiles%\YPOPs|ypops.log
[*XN Resource Editor]
LangSecRef=3024
Detect=HKCU\Software\Woozle\XN Resource Editor
Default=True
RegKey1=HKCU\Software\Woozle\XN Resource Editor\Recent Files
[*ZipGenius]
LangSecRef=3024
Detect=HKCU\Software\M.Dev Software\ZG5
Default=True
RegKey1=HKCU\Software\M.Dev Software\ZG5\MRU Items
FileKey1=%appdata%\ZipGenius|mru.dat
[*ZX32 ZX Spectrum Emulator v1.03]
LangSecRef=3021
Detect=HKCU\Software\VK\zx32\1.03
Default=True
RegKey1=HKCU\Software\VK\zx32\1.03\FileMRU
Just unzip the zip file to where CCleaner is installed.
Your Friendly Neighborhood Piriform Forum Moderator
Quick Links: Forum Rules | Piriform Docs | Add a program to winapp2.ini
Go to the top of the page
+Quote Post
TwistedMetal
post Nov 26 2008, 05:59 PM
Post #2
Forum Moderator
Group Icon
Group: Moderators
Updated 11/26/08
Added Adobe Flash Player
Added Copernic Desktop Search
Added FrostWire
Added MS Works Suite 2006
Added NA Framework Agent
Added The Bat
+Quote Post
TwistedMetal
post Feb 22 2009, 03:12 PM
Post #3
Forum Moderator
Group Icon
Group: Moderators
Updated 2/22/09
Added Ashampoo Burning Studio 09
Added Auslogics Free Utilities
Added AutoIt3
Added Avi-Mux GUI
Added LogMeIn
Added MS Visual Studio.NET 03
Added PDFCreator
Added TeraCopy
Updated Mp3tag
+Quote Post
TwistedMetal
post Feb 22 2009, 04:56 PM
Post #4
Forum Moderator
Group Icon
Group: Moderators
Updated 2/22/09
Minor update:
Removed duplicate entries
Fixed a mistake
+Quote Post
Closed TopicStart new topic
RSS Lo-Fi Version Time is now: 20th November 2009 - 10:14 PM
