Piriform Community Forums: CAN’T RESTORE REGISTRY! - Piriform Community Forums
  • (3 Pages)
  • 1
  • 2
  • 3
  • You cannot start a new topic
  • You cannot reply to this topic
#1 User is offline   product53
  • Member
  • PipPip
  • Group: Members
Posted 28 January 2006 - 11:25 PM
When trying to restore the registry I get the following error message:
“Cannot import C:\Documents: Error opening the file. There may be a disk or file system error.”
This is very serious. I need to restore some of the files from the last time I ran CCleaner. I thought this thing was safe to use!?!?!?!
0
#2 User is offline   rridgely
  • I hate computers
  • Icon
  • Group: Moderators
  • Gender:Male
Posted 28 January 2006 - 11:40 PM
What did you remove?(what problems are you getting because of this?)
0
#3 User is offline   lokoike
  • Hufu FTW!!!
  • PipPipPipPip
  • Group: Members
  • Gender:Male
  • Interests:Hardware / software troubleshooting, open-source / freeware, Popular Mechanics, my g/f, and hufu.
Posted 28 January 2006 - 11:45 PM
You can't restore files with CCleaner, only registry entries. And CCleaner doesn't remove any necessary files, so if you computer is acting goofy due to deleted files, CCleaner is not the culprit.
Save a tree, eat a beaver.
Save a tree, wipe with an owl.
Every time a bell rings, a thread gets hijacked!
ding, ding!
Give Andavari lots of money and maybe even consider getting K a DVD-RW drive.
If it's not Scottish, IT'S CRAP!!!
0
#4 User is offline   product53
  • Member
  • PipPip
  • Group: Members
Posted 29 January 2006 - 12:08 AM
When I try to open Windows Media Player, the following error message appears:
“An internal application error has occurred.”
It has something to do with: “Reregister Jscript.dll and Vbscript.dll,” According to http://support.micro...31430#appliesto , - but these instructions are too vague.
Anyway, I try to avoid editing the registry manualy - I would perfer to have a safe application do it. That's why I use CCleaner in the firstplace.
0
#5 User is offline   rridgely
  • I hate computers
  • Icon
  • Group: Moderators
  • Gender:Male
Posted 29 January 2006 - 12:12 AM
Yeah ccleaner didnt cause this...
Anyway use this to fix it:
http://www.softpedia...ial-a-fix.shtml
Download it and hit the green arrow. Then hit go. Let me know if that solves your problem.(make sure all other programs are closed while running it.)
0
#6 User is offline   lokoike
  • Hufu FTW!!!
  • PipPipPipPip
  • Group: Members
  • Gender:Male
Posted 29 January 2006 - 12:14 AM
Do you remember what registry keys you deleted? Did they have anything to do with Windows Media Player?
I would suggest downloading and reinstalling WMP. You can download version 10 here. But once again, I highly doubt CCleaner was the culprit, as I have used numerous versions of it, and never had any problems with it conflicting with other apps, including WMP.
ding, ding!
0
#7 User is offline   product53
  • Member
  • PipPip
  • Group: Members
Posted 29 January 2006 - 12:29 AM
Something funky is happening… Now IE is acting-up. I have been getting an “error on page” message trying to view topics at Windows Newsgroups, and when I try to download DIAL A FIX I get: “The page cannot be displayed”
0
#8 User is offline   product53
  • Member
  • PipPip
  • Group: Members
Posted 29 January 2006 - 12:41 AM
Never mind.. I found a mirror for download.
0
#9 User is offline   product53
  • Member
  • PipPip
  • Group: Members
Posted 29 January 2006 - 12:58 AM
I ran Dial a Fix but it didn’t fix the problem. There was an error with Register WUAU DLLs.
0
#10 User is offline   krit86lr
  • Power Member
  • PipPipPipPip
  • Group: Members
  • Gender:Female
Posted 29 January 2006 - 12:59 AM
I was wondering if you could confirm a suspicion of mine. I've noticed when downloading things from Microsoft that if I 'run' instead of 'save - run' that the downloads sometimes go to the Temp folder. If a download ends up in a Temp folder would that cause problems like the one in this thread? CCleaner does clean up temp folders (right?)?
Thank you!
K
0
#11 User is offline   lokoike
  • Hufu FTW!!!
  • PipPipPipPip
  • Group: Members
  • Gender:Male
Posted 29 January 2006 - 05:28 AM
If a file is in use (for example, if the file is an installer and you are using it), I don't believe CCleaner will touch it. I know that Windows won't let you delete files that are in use, such as a song that is playing, or a picture that is being edited, and I think CCleaner runs under the same rules.
Plus, CCleaner will only clean out the Temp folder if you tell it to, and hopefully you aren't running CCleaner while you are installing an application! :D
ding, ding!
0
#12 User is offline   product53
  • Member
  • PipPip
  • Group: Members
Posted 29 January 2006 - 06:40 AM
Why do I get an error message when I try to restore the registry backup that CCleaner created? Regardless of what caused the problem, I first detected it shortly after running CCleaner. If I am to troubleshoot properly, I need to undo CCleaner's changes to the registry. Presently this is not possible.
0
#13 User is offline   krit86lr
  • Power Member
  • PipPipPipPip
  • Group: Members
  • Gender:Female
Posted 29 January 2006 - 06:44 AM
Ha Ha Smart A**.
:D K
0
#14 User is offline   lokoike
  • Hufu FTW!!!
  • PipPipPipPip
  • Group: Members
  • Gender:Male
Posted 29 January 2006 - 06:48 AM
Honestly, I've never gotten that message before, but if it is a file system or disk error, I do have one suggestion:
1. Open up My Computer, and right-click the drive that Windows is on (most likely "Local Disk (C:)")
2. Select Properties at the bottom of the list that comes up
3. Click the Tools tab in the window that appears
4. Click the Check Now button under the Error-checking section
5. Check both boxes and click Start
6. After choosing Yes, restart the computer, and let it run the scan
This will hopefully repair any disk/file system errors that you are encountering. Certainly worth a try!
View Postkrit86lr, on Jan 29 2006, 12:44 AM, said:
Ha Ha Smart A**.
:D K
Sorry, couldn't resist! :D
ding, ding!
0
#15 User is offline   rridgely
  • I hate computers
  • Icon
  • Group: Moderators
  • Gender:Male
He is right though krit86lr. :D
product53 hold off for a while, I'm waiting for a response from the creator of DAF if DAF will fix your problem.
0
#16 User is offline   krit86lr
  • Power Member
  • PipPipPipPip
  • Group: Members
  • Gender:Female
Posted 29 January 2006 - 06:52 AM
Point taken. I bow to your wisdom o great one :lol:
K
0
#17 User is offline   Andavari
  • Captain Spectacular
  • Icon
  • Group: Moderators
  • Gender:Male
Posted 29 January 2006 - 01:08 PM
A reason why merging a .reg file can fail is if the shell extension 'Merge' is broken and missing parameters.
Instead try to import the CCleaner .reg backup using the main Regedit GUI:
1. Start, run, type in regedit.exe
2. Click File->Import, browse the the .reg backup.
If this doesn't work you'll have to log onto your system as the System Administrator. If it still doesn't work try it as the System Administrator in Safe Mode, as you may have some sort of security software blocking the importing of .reg files.
Piriform Internal Links:
Piriform Docs - Official documentation for Piriform software.
Solutions when CCleaner won't install.
External Links:
ERUNT · Macrium Reflect Free Edition · Paragon Rescue Kit Express
0
#18 User is offline   rridgely
  • I hate computers
  • Icon
  • Group: Moderators
  • Gender:Male
Posted 29 January 2006 - 07:53 PM
Ok djlizard said that dial a fix does register both of those dlls. Turn off all security programs you have running(AV, spyware, ect) and make sure that your loged in as an admin. Then hit the green check mark and then go and see if it will work.(reboot after running it)
0
#19 User is offline   product53
  • Member
  • PipPip
  • Group: Members
Posted 29 January 2006 - 10:49 PM
I still get the same error message:
“There was an error while registering the object C:\WINDOWS\system32\muweb.dll (with flag(s): “/”).”
Also, I cannot use Regedit to import the file. I get the following error message:
“Cannot import C:\Documents and Settings\My Documents\regbkup.reg: Not all data was successfully written to the registry. Some keys are open by the system or other processes.”
0
#20 User is offline   krit86lr
  • Power Member
  • PipPipPipPip
  • Group: Members
  • Gender:Female
Posted 29 January 2006 - 11:26 PM
What happens if you click Start > Run > regsver32 muweb.dll ? This will register a .dll
K
0
  • (3 Pages)
  • 1
  • 2
  • 3
