When deleting IE7 files, CC seems to use rundll32.exe (cmd line : RunDll32.exe InetCpl.cpl,ClearMyTracksByProcess 16)
The problem is that rundll32 process is not properly shut down, sometimes yes, sometimes no
Things go that way :
1) launch rundll32 to clean IE7
2) cleaning's done but rundll32 process is still alive
3) shuting down CC, rundll32 process is still alive
That's the way I can have 3 or 4 rundll32 process running on the system
So my questions are :
- is it really a bug (I mean it could be the way it works) ?
- can you fix it ?
Thanks
