Help - Search - Members
Full Version: Discrepancy in files found between portable and regular CCleaner (2.25)
Piriform Community Forums > Piriform Software > CCleaner Discussion > CCleaner Bug Reporting
JDPower
Don't know if this is v2.25 specific as I've only just discovered it but have found the portable version is finding Flash Player files that the installable version doesn't pick up for some reason. The files the portable version is picking up are:
C:\Documents and Settings\user\Application Data\Macromedia\Flash Player\#SharedObjects\EB8VEWFA\mail.google.com\wakeup.sol
C:\Documents and Settings\user\Application Data\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#mail.google.com\settings.sol
This is on XPHome, both versions are 2.25, neither have any exclusions or inclusions set huh.gif
MrT
Hi
The same CCleaner.exe is used for regular and portable version, so they should produce the same results.
Can you please let us know if you have any instances of IE (or other browsers) running while analyzing?
Would you be able to log off and then run the analyzes again?
Please let us know if problem persists.
JDPower
Well after much head scratching and trial and error deletions of sections of CCleaner.ini the penny finally dropped dropped when deleting the cookies to keep section of the ini cured the problem. Of course, .sol files are used for flash cookies aren't they, it's the Gmail Flash cookies and I have the Gmail cookie set to keep.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2010 Invision Power Services, Inc.
